Question about Motorola Mobility MoroKRZR K1m Cellular Phone
Can't clear the calculator error on my Motorola K1m cellphone.
Where does the sim card enter in motorola k1m
Your cell phone Motorola KRZR K1m uses CDMA network and does not use any sim cards. Only GSM network phones have sim card slots.
May 06, 2011 | Motorola Cell Phones
How do i master reset motorola k1m if i forgot my pass code
Please remember after you finish all of this, you NEED to reboot your phone for everything to take effect. And only do this with a K1m, not a K1.
Master reset/clear is not in testmode on K1m. You need to either use software2_bing.gif such as radiocomm etc or you can do it from opcode screen.
Perform at your own risk!!! This will delete everything (contacts, pics, etc...), not just contacts!
Goto opcode screen:
Enter: CLR, 0, 4, 8, 2, 6, 3, * (Note: Must be done quickly.)
From the opcode screen:
Enter 18* and click center radial button on phone. Then enter 0 and click on center radial button.
-wait and it will say success after a short time.
Enter 18* and click center radial button on phone. Then enter 1 and click on center radial button.
Exit out. Contacts, Pix & Flix, Called #’s, etc should all be deleted…
Note:
18* enter, 0 enter – does master reset.
18* enter, 1 enter – does master clear.
WARNING: There are other #’s that can be entered…but I think you can really BREAK/BRICK your phone in there quite easily…
Performing master reset/clear using software like radiocomm is proven and works well, but if you do not have the software and want to wipe phone before selling, returning, etc… then…
Apr 03, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
How to reformat a motorola k1 phones
download the k1 software for your cell phone get the usb cable then connect the cellphone to the computer then install the software and it will format everything. i hope it helps
Feb 16, 2010 | Motorola Mobility MoroKRZR K1m Cellular...
Naghahang ung cellphone ko! letse!
speaking taglog sir? anyway try to remove the memory card first and try to open it again. if still not working then try to reformat your phone.
Nov 04, 2009 | Motorola Mobility KRZR K1m Cellular Phone
Need web site to get to read manual for Motorola Krzr K1m
Go to www.motorola.com. Click on the picture above "for consumers." Choose "mobile phones" near the top middle of the page. Then, in the "quick search" box on the right type in K1m. On the right near the top of the next page choose "owner support" and on the next screen will be "manuals and user guides" on the right.
Not exactly a manual, but you can go to www.verizonwireless.com. On the red bar, near the right, click on "support". Choose Motorola, then your phone model. I don't know exactly what information you seek, but you can find answers to many of your questions there.
Sep 17, 2009 | Motorola Mobility KRZR K1m Cellular Phone
The alarm clock does not ring
I would try this if you think it is a software problem, I found this in the K1m users manual.
master clear Reset all options except unlock code, security code, and lifetime timer, and clear all user settings and entries: Warning: This option erases all userentered information stored in your phone memory, including phonebook entries and downloaded files. Once you erase the information, it cannot be recovered. It resets all options to their factory settings except for the unlock code, security code, and lifetime timer. Find it: s > w Settings > Initial Setup > Master Clear To reset all options, you need to enter the Security Code (000000).
this should fix you problem, I do this to my Nokia N95-2 often to keep it running sweet.
Jan 07, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
Can the red motorola K1m model use a sim card
hi
no, but if that happened it's gonna be expensive.
Jan 06, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
Manual reformat my Motorola KRZR K1 cell phone
1st. install your motorola k1 pc suite into your computer. 2nd. download the phone software update from www.motorola.com. 3rd. install the phone software update into your computer. 4th. run the phone software update and connect your cellphone using the usb data cable. do this while you are connected to the internet. 5th. do not disconnect until it is not finished.
Dec 06, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Motorola k1m
try 1234 or press the menu key when the phone prompts for the security code enter 000000.
May 30, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Bricked k1m
yes there is but it is best to take it to a mobile service center professional and have them fix it for you.
Feb 07, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Motorola Mobility MoroKRZR K1m Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
