Question about Singer Sewing Machines
Singer TouchTronic 2005 won't wind bobbin thread on bobbin. I've followed all the directions in the manual...any suggestions?
5 Suggested Answers
SOURCE: Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Posted on Dec 23, 2007
Zenqi
  • 208 Answers
SOURCE: Bobbin Winding problem
Pass the bitter end of the thread from the inside of the bobbin and up through the hole or slot in the bobbin to the top. Hold on to the thread as it turns to get it going.
Posted on Jul 11, 2009
  • 54 Answers
SOURCE: touch tronic 2005 by singer won't wind bobbin
bobbin case is out of adjustment
Posted on Aug 17, 2010
SOURCE: Singer Touchtronic 2000 - it
Take your thread that is under the presser foot and wind the thread on the tension disk. It is located right above and to the left of the presser foot. Then you will drop in the bobbin and slide the thread into the **** in the top of the bobbin. Push the little white tab in the bobbin slot all the way to the right until it is in the center of the bobbin. Then press the foot feed and the bobbin should wind.
Posted on Nov 21, 2011
Singer 3232 machine was sewing fine now motor runs but needle does not move up and down
Check if the machine is in the bobbin winding mode. To wind the bobbin, the bobbin spindle has to be moved to the right. (The hand wheel will not turn if the bobbin spindle is in this position.) If it is, move the spindle to the left.
If the hand wheel turns, then check for a thread jam. Remove the top thread and take out the bobbin case. Gently turn the hand wheel forward and backwards until the thread comes free of the hook in the bobbin race. Follow this by cleaning any lint from the bobbin race of the sewing machine.
The last possibility is that the belt has failed. This belt transfers the energy from the motor to the needle bar. One source of the belt is http://www.sewingpartsonline.com/motor-belt-singer-007158xxl5.aspx . You can find YouTube videos on changing the belt. There are other parts that transfer the forces form the belt to the needle bar. However, I suggest you find a good sewing machine mechanic if any of these parts fail.
The manual has good pictures of the bobbin spindle on page 11 (page 18 of the PDF). Singer has the manual on their support page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf .
I hope this helps.
Jul 28, 2017 | Singer Sewing Machines
Trying to wind the bobbin on my singer 6268 but the thread keeps winding under the bobbin. What am I doing wrong?
if the bobbin winder is driven of the end of the machine then you may have to guide the thread as it winds onto the bobbin
if you are allowing the thread to come directly from the reel and it is not in line to the bobbin then what you have is what will happen
Jul 21, 2015 | Singer Sewing Machines
Bobbin won't wind on Singer futura CE-100
My singer hasn't wound bobbins for years and I don't care because I use a Side Winder bobbin winder. It's much easier than takining the thread off the machine anyway. Available from Hancock, Jo Ann or even Wal Mart for about $30.
Sep 09, 2012 | Singer CE-100 Futura Computerized Sewing...
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
Singer 6268 bobbin winding
I've never seen this type of winding system. But from the manual on page 10, it shows that in order to disengage the machine from sewing mode.. you need to have the bobbin cover slide plate slightly open.
http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf
Also make sure that your bobbin doesn't have any burrs. If it does, toss it and use a new one.
Jul 21, 2012 | Singer Sewing Machines
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
I have a singer touch tronic sewing machine. I need to fill the bobbin and I cannot get it to work. where can I buy more bobbins that have already been filled to fit my machine
Has the bobbin winder worked in the past and now faulting. Or are you unsure on how to use it?
There is a manual for a Touchtronic 2000 here http://www.singerco.com/uploads/download/432_touchtronic.pdf there may be more than one model Touch Tronic so plse check the serial number plate on the side of your machine to establish the actual model number, usually near the power inlet plug. then search for the appropriate manual at http://www.singerco.com/accessories/instruction-manuals. This excerpt shows that you wind the bobbin insitu in the bobbin case.
I'm not a fan of prewound bobbins, far better to deal with the bobbin winder issue. Winding your own thread means you can get far better colour matching to the fabric, and ensure you've got quality thread on the machine, and same thread top and bottom. (I prefer a quality cotton wrapped polyester or a polyester thread, Guttermann, Molynecke or Sylko Supreme). All of these factors affect stitching quality and the finished appearance of a seam.
Did you know that you can buy a freestanding unit to wind bobbins? Link to this item is here. http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx You may well find that this is the better solution to winding bobbins for this machine as winding them inside the bobbin housing doesn't give you a lot of control over the way the thread feeds onto the bobbin.
Jun 27, 2011 | Sewing Machines
Show me how to use singer sewing machine57815
You can download a manual from http://www.singerco.com/accessories/manuals.html, just type your model number into the search field to locate it then download the pdf file to your PC. This is a basic Zig zag machine so carefully follow the manual instructions to wind a bobbin, thread up and stitch, just make sure you follow the directions to wind a bobbin, and then put it in the right way and click the thread into the tension spring.
Dec 08, 2010 | Singer 57815 Mechanical Sewing Machine
Singer Touchtronic 2000 - it will not wind a bobbin, I have found a manual onlin that says you just drop it in and push the foot feed and it will wind the bobbin but it doesn't do anything.
Oct 24, 2010 | Singer Sewing Machines
Sewing Machines Logo
232 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
