SOURCE: about wi-fi
Windows XP has a built in wifi configuration tool, previous versions of windows dont have this feature. But if you were to buy a wireless card it comes with software for wireless to work on all versions of windows from 98 - XP most if not all new laptops have wifi built in & that will be able to share your broadband connection through the netgear router. You can configure the laptop & pc to share files & printer between each other, easy way of doing that is by using the wireless network setup wizard which can be found in Start -> All Prograns -> Accessories -> Communications -> Wireless Network Setup Wizard.
SOURCE: wi-fi on e50
E50 doesnt have wifi feature i.e there is no hardware to access wifi,so u cant install wifi settings,if u need wifi,change the handset E60 has wifi
SOURCE: acer aspire 3000 wi fi problem
First you need to make sure the Wireless drivers are installed in the computer, aswell the Acer Related utilities. Then Most acer laptops have a button on one of the sides or on the top of the laptop to turn on the wireless.
To find out if you have the acer related programs installed, try pressing some of the buttons on the top of the laptop, that are NOT apart of the keyboard, they should open up acer or related programs, if noting happens the programs are not installed, one of the buttons is likely to turn on the wireless.
To check if the wireless drivers are installed press start -> run -> type: msinfo32 (OR press down the windows key and press R, then let go and type msinfo32 into the run menu that comes up and click OK)
On the program, left side, open up components from the + next to it, then find Problem devices from the list and click on it, on the right you will see a list of devices that are not installed or not working.
If the list is empty, everything is properly installed. and you should be able to get your wireless to turn on by pressing on the wireless button on the laptop, and then use your computer to connect to a wireless network.
If you need further assistance let me know.
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
SOURCE: trying to enable the wi-fi on my acer 3693WLMi
install an application called 'Launch Manager' That will help.
You didn't say what model?
Acer Extensa 2000/2500 Series --- Far right launch button above the keyboard
Acer Travelmate C Series ---Far left hot key and then choose WLAN from menu that appears
Acer Aspire 1000 Series --Launch Keys above the keyboard
Acer Aspire 1640Z ---- Launch Keys above the keyboard
Acer Aspire 1690 ---- Launch Keys above the keyboard
Acer Aspire 2000 Series ---- Button on the front of the laptop
Acer Aspire 2012 ---- Launch Keys above the keyboard
Acer Ferrari 3000 ---- Button on the front of the laptop
Acer Ferrari 3020 ---- Button on the front of the laptop
Acer Ferrari 3400 ---- Button on the front of the laptop
Acer Ferrari 4000 ---- Button on the front of the laptop
If you don;t have the drivers go to the Acer site and download them, and install.
