Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
When i start the bike, the starter will spin out a couple of times before it finally catches and turns the engine. this happened for about a week, until it finally stopped catching. now it just keeps slipping, making a whining sound. do you usually have to replace the starter, or the solenoid?
  • 116 Answers
Its probably the starter drive you have to pull the starter to change it though with the cost of hd parts add the time to change the drive,not to mention the real possibillity that the rest of the starter may be tired i would go looking for an aftermarket starter the prices have really come down on them
Posted on Jan 30, 2010
  • 23 Answers
You don't say what year/model your bike is. None the less, most likely the starter bendix is shot. This can happen in an instant (especially if you have a mechanical advance and the springs are weak or broken.) This would make a sort of "zing"ing sound when you try to start it. The solenoid's job is to push the bendix into position to engage the starter ring on the clutch hub. The starter motor won't turn until the solenoid is fully engaged. Check the bendix - it should turn freely in one direction and not at all in the other. Good luck.
Posted on Aug 20, 2009
Won't go into gear without engine running, starter just spins without catching.
The starter clutch needs to be replaced. An alternator sgop will usually rebuild these for 1/2 of a new one. Rebu .A thumbs up would be greatly appreciated if this answer is helpful to you. go-into-gear-without-engine-running-4d5i0utctl2htkxwobhufr12-1-0.jpg
Mar 26, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
97 roadking, not going into gear, starter just spinning while bike is in neutral, in gear bike just free-wheeling push the starter and bike lurches forward but then starter just spins
Hi Rod, sounds like your starter drive is going south. I'm sorry you can't find the first and very best tool your Road King ever needed, but don't despair for a mere $6.50 you can download another one at the website below:
Harley Davidson Manuals Mark Workshop
Good luck and enjoy the video.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 26, 2014 | Harley Davidson FLHR-FLHRI Road king...
I have a 2003 Utilimaster truck powered by a 5.7 Chevy 350. Last week it was turning over, but struggled to turn over. It started finally and I had no trouble cranking it for the rest of the day. The...
Sounds like you have a bad starter drive gear assembly (the gear on the starter that engages the flywheel gear). The drive gear has a one way clutch to prevent spinning the starter with the flywheel on engine start. When the clutch goes bad it does not spin the starter drive gear. If that's the case you can replace the starter drive rather than the whole starter, and you should also check the flywheel gear teeth to make sure none are broken or worn excessively.
Jul 24, 2011 | 1999 Chevrolet 3500
1987 FXLR 80" 11-1 compression Evo Engine. S&S heads, barrels, and carb matched to a '91 clutch assembly and a Spyke starter. Have a continual problem of having the starter jack-shaft "fall" and...
The problem on your starter sounds like the "overrunning clutch" in the starter. The jackshaft cannot "fall" as the outer end of it is supported by the outer primary cover. It's engaging your ring gear, just not turning the engine. If the start spins, this means the jackshaft has been pushed into the engaged position because the starter will not spin until the solenoid plunger is in the full forward position. So, the only thing left is the "starter clutch". With a compression ratio like you have, you should be running compression releases if you wish to keep even a Spyke starter in the bike.
As for the electrical problem, it sounds like you've got a stator shorting out on you. I had one customer with a 90 FXR that was happening to. His bike would run fine for days and weeks but ever so often, it wouldn't start due to a dead battery and he'd just been riding it. We replaced the entire charging system. The only thing that we hadn't replaced prior to that was the stator. Now, if you wish to prove this, you'll have to catch the problem when it's not charging the battery. If you wish, you can purchase a voltmeter at any automotive parts house and install it on your bike. The battery should charge at 14.5 to 14.8 volts. Anything below that, the battery will slowly discharge. If you can, test the stator output. Unplug the connector at the cases. Inspect the connector to make sure the connections are in good shape up inside the plug. You need one those hold downs that keep this plug tight as well. Using a DVOM (Digital Volt Ohm Meter) put one of the meter leads on each pin in the case, put the meter in AC volts, 50 volt range. Start the engine and you should read about 25 volts or greater. If not, the stator is defective.
Good Luck
Steve.
Jun 12, 2010 | 1993 Harley Davidson FXR Super Glide
Some times the engine will not turn over
Yes, I would agree that you've got a bad starter relay. As for the engine quitting while you are riding, that could be many different things - but when combined with the starting problem, I would suspect a bad electrical connection at the relay - or between the battery and the relay. I don't know for sure about your bike but generally most bikes have the main power connector near - or at - the starter relay. From there the power goes directly to the fuses and gets distributed to the rest of the bike from that point.
Again, I am not intimately familiar with your bike, but to find the relay, just follow the clicking sound. Usually, the relay isn't too far from the battery or the main fuse box. The starter relay will always have two large cables attached to it - one from the positive side of the battery, the other going to the starter motor.
Mar 20, 2010 | 2007 Bajaj Pulsar 150
Once or twice a week, I have problems with the starter. I push the button and hear the starter spinning but nothing else happens. Hit the button a couple of times and it catches and starts. This problem...
I seriously doubt the brand of oil you use is going to affect the starter. If you are hearing the starter spin but only get sporadic engagement, the starter's bendix may be worn and needs to be replaced. There is a VTX forum you can go to with all manner of VTX guys there to answer your questions. The url is: http://www.vtxcafe.com/forum.php
Feb 02, 2010 | 2005 Honda VTX 1300 R
My 99 chevy malibu takes a while to start. it sounds like its trying to catch but it takes a couple of tries. someone told me it was the starter. does that sound right?is so where would it be located?
define trying to catch. is the engune turning over but sounding like it may start then finally does? or does the starter spin but the engine is not turning unless you turn the key to start a few times if it is the latter it could very well be the starter. check to see if you have an oil leak onto the starter. if it very greasey then you will need to adress the oil leak too. the starter is located on the lower right side of the engine. (passanger side.)
Nov 11, 2009 | 1999 Chevrolet Malibu
My volvo 850 just had a tune-up but now when I turn the ignition-
does your starter turn yet not making contact with flyweel.
If so then its your starter drive or solinoid.
Nov 17, 2008 | 1996 Volvo 850
Lands Phones Logo
352 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
