Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer not heating up
I've had our Duet Dryer for about 3 years and when it works its great! But it seems to gather alot of lint inside which gradually lessens its drying capabilities over time. Twice I've taken off the vent hose & thoroughly cleaned it out and I've had the wall vents cleaned out twice as well. This is a time consuming and somewhat expensive project which I never look forward to. Recently it was showing the same symptoms and I was about to do the routine again but this time it completely stopped heating up at all! From reading some of these blogs, looks like it may have a bigger problem this time. Any thoughts? I've got kids coming back from camp in two days, so this is about to be an emergency!
  • Dana Newcombe
    Dana Newcombe May 11, 2010
    Is it gas or electric. Is it 110volt or 220volt?
    Scholar:
  • 84 Answers
DOes the the dryer run still? But with no heat? I would look into you fuses...the fuses are located on the botton....take the bottom panel off by unscrewing the 2 bottom screw (they are kind of sunken but they are there) Once that is off look down and there are fuses...You need to get a multi meter or someone that you know that has one and know to to use it. there are are 3 fuse/thermostats down ther, one of themm might be bad and you have to find out which one it is....you need to get a multimeter and and put it on the ohms setting..now with the cord un-plugged from the dry, check the thermofuse first,(its the white skinny small ovel shaped fuse) take the wires off and put your meter leads of you meter on the fuse where the wires were connected. Meter should be on the ohms setting. If it reads "OL" than thats your problem. If it reads 0.0 ohms then its good fuse. plug the wires back and try the next one next to it. The next one next to it is a thermistor,(its black color i believ) this one should read more than 0.0 ohms. If it reads something besides "OL" then its good. If its "OL" then its bad. if it checks out ok then plug the wires back on it. theres another one on the burner tube i believe. this one is further in, do the same test and see what the meter tells you. If you get an "OL" any of them then change that one out....hopefully this helps, let me kno what happens find out
Posted on Jul 30, 2009
Whirlpool duet dryer
Run the dryer for 2-5 minutes. Check to see if it has heat inside. If not, you have an internal problem.
If heat is generated, check your dryer lint trap. It must be clean before every dry cycle to dry properly and efficently. If the trap is clean and heat is generated, check the tubes behind the dryer for disposing of the lint.
Oct 15, 2013 | Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Whirlpool duet electronic gas dryer noy heating up
You need to excess the back and unplug and put vacum hose through vent hose to dryer and use a wet/vac it has to be clogged.Is the dryer lighting up,you also may want to get a applance tech. thats gas certifed.to check it out
Jul 17, 2010 | Whirlpool GEW9250 Electric Dryer
My dryer wont heat
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 05, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Lint has built up inside the 3 plastic fins of Whirlpool Duet
What is the model Number. Does your lint screen go thru the top or is it in the door.
Jan 31, 2010 | Whirlpool Dryers
Whirlpool LGR76481cqo gas dryer not getting hot
FIRST THING YOU SHOULD ALWAYS CHECK IS THE INSIDE OF THE DRYER AND THE DUCK WORK TO MAKE SURE THEY ARE CLEAN OF ALL LINT THIS INCLUDES THE MOTOR AREA LINT GATHERS AROUND PARTS AND STOPS THEM FROM WORKING
PROPERLY THERE ARE THERMAL DISCS INSIDE THAT CONTROL THE HEAT ONE COULD BE BAD. I CAN NOT FIND THIS MODEL NUMBER THRU WHIRLPOOL IS THIS THE WRITE NUMBER
Aug 11, 2009 | Whirlpool Dryers
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet dryer is taking 3 cycles to dry????
have you checked your lint trap to make sure that it is clean after every load? Also the lint vent to the outside may be clogged and will not let the dryer vent like it should. This is dangerous. So check and replace if needed.
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GEW9250 Electric Dryer Logo
616 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
