Question about Danby (DAR604BLS) Refrigerator
Refridgerator side of my side by side is Hot
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} We have a GE Gss22wgph ww side-by-side refrigerator/freezer.
First some stats:
The Freezer side is working fine it drop the temp down to about 0 in a short time.
The air flow from the freezer side to the refrigerator is working.
Repair man check the air flow and the defrost system and said it was working fine.
Problem:
While the freezer side is working fine The Refrigerator side is heating up to over 120.
This is scary and could start a fire.
I had a repair man out and he said that it was something new to him in his 30 years of working on refrigerators.
Is there anything I can do to repair this problem?
Thanks for Your Help
Roy
  • 3 more comments
  • roycapps Jul 29, 2009
    No the light of out when the doors are closed... Would that cause the frig to go over 120 deg?
    Now did I tell you that the inside sides of the refrigerator gets very hot to the touch. Like there are coils in the sides and top of the frig part of the side by side refrigator/Freezer.
    Thank You for Your Help
    Roy
    No... the lights go off when the doors are closed
  • roycapps Jul 30, 2009
    Thanks for the help.
    Your Right the light is not going off.
    I believe that the problem is... The door needs to be lifted up a bit so the switch is hit by the door and turns the lights off.
    Thanks For Your Help
    Roy
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    There is a loop from the condenser which passes around the door opening to use waste heat from the refrigerator to warm this area to prevent condensation from forming near the door gaskets. This is a normal thing, and saves energy, as older products used electric strip heaters to do the same job. I've never heard of a 120 FF temp before without some light staying on. I'd double check the air flow into the refrig (through the motorized air damper at the very top back left side of the FF compartment). Your model does not have the Climate Keeper heated drawer in the bottom of the FF compartment, so the only thing in the FF compartment that should be able to produce heat is the light bulb. Ice maker working and fan blowing in FRZ section?
    Are the lights staying on in the refrig when the doors are closed?
  • 1,543 Answers
Glad I was able to be of assistance. Did not post as a solution previously as I needed to ask a few questions first.
Posted on Jul 30, 2009
    Carl Schulzetenberg Jul 31, 2009
    thought that'....
    Jul 30, 2009- Thanks for the help. Your Right the light is not going off. I believe that the problem is... The door needs to be lifted up a bit so the switch is hit by the door and turns the lights off. Thanks For Your Help Roy
    sounds like a 4 thumbs up score. ??????? Was wondering why you only rated it a 3?
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
Refridgerator is not cooling,the freezer is still frozen compresser is hot
FIRST YOU MIGHT CHECK THE FREEZER AND HEAR IF FAN IS RUNNING IF IS NOT THAT IS PROBABLY THE CAUSE .
Feb 14, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
GE GSS22WGPH WW won't defrost. Already changed heater.
Replace the thermisters located one at bottom of freezer in back which is the most viewable the other is in the top of the freezer by the fan motor they cost about 15.00 apiece.
Mar 29, 2009 | Danby (DAR604BLS) Refrigerator
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Danby (DAR604BLS) Refrigerator Logo
351 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
