- I did all the things you said and replaced 110 with 150. Once i kept
every thing back and turned on the tv I get nothing I see some green
light very little but i get no picture or sound.
If you are referring to the convergence alignment of red,green and blue........will require technical and mechanical skills.....
1) Pull chassis
2) Replace both STK392-110 convergence IC's
3) Reset alignment as needed........................................T.
Comments:
May 28, 2008
- Suggest reading all posts about your make,model and symptom.......T.
color disappeared suddenly form a SONY 60 inch rear projection TV and became black and white in the...
(More)
color disappeared suddenly form a SONY 60 inch rear projection TV and became black and white in the main screen while I can still see color in the small PIP screen
none of the rca, coax, or s-video inputs on my toshiba 42h81 tv work. the screen is just static with...
(More)
none of the rca, coax, or s-video inputs on my toshiba 42h81 tv work. the screen is just static with a couple of vertical lines on the right side of the screen
