Question about Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
My Sharp 27DV-S100 will not accept DVD discs.
When I put in the DVD it shows a "Wrong Disc" on the screen. Do you think the DVD player needs cleaning? I cannot find any answers in the manual. Dieing to watch my **** She Wrote movies, Gerri B
  • 147 Answers
Replace the dvd mechanism assembly.usually
runs 60-90 bucks.you can buy the part from
encompass.com.the dvd mech cannot be repaired by individual parts.the entire dvd mech
must be changed and is available.this may
require a technician to repair this depending on
how mechanically inclined you are.the part is
available to the public.
Posted on Jul 29, 2009
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Wrong disc?
to clean the lens you'll need to buy a lens cleaner.its a cd which cleans.so its no problem to load it.now if even the lens cleaner is not loading ,i suggest you bring it to a tech nearest you.
May 27, 2009 | Coby TF-DVD8107 Portable DVD Player with...
Reads "wrong disc" when I insert any disc
Tru cleaning your lens,(pysically) give it a blow ,or similar
May 03, 2009 | Spectroniq PD-1100 DVD Player
Won't accept any dvd disc
It sounds like the Laser went out. Buy a new dvd player
Jan 13, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
Can't Get Any TV picture on mySharp 27DV-S100 TV-VCR-DVD combo
open back up the set and look closly at all of the plug connections and cables as you might not have pulled one out all the way but may have in inadvertantly pulled on a cable of one of them and pulled one out have way or just a little. My freind it happens to the professionals all the time. Make sure you check all the plugs on the VCR as well as the tv that they are instraight and flush. Good Luck Ps Please dont forget to rate this.
Oct 15, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
DVD Player won't read
I have to disagree with the previous answer you got. It's a common scenario that someone uses his DVD player to play CD's and then the point is lost. DVD players DO get plagued with dusty lenses, same as any other disc player. If you can get to the lens its worth a try, but from your post it seems that you should take it to a pro lab. I say this because you'll have to open the TV chasis to get there, and TV's are just about the most dangerous home appliance to mess with. Touch the wrong spot, even when plugged out, and you can get bit by enough voltages to kill. Take care and good luck
Mar 22, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Sharp 27DV-S100 27 in. TV/VCR/DVD Combo Logo
212 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
