SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
SOURCE: Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
SOURCE: how to change the bulb in a jes1288sh02 ge microwave oven
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a
microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The
screws you need to remove should be pretty obvious, but a special
driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the
screws back in the right holes, since some may be special grounding
screws.
You can find an exploded view showing the the lamp assembly (location refer# 280) here.
You can order the lamp assembly by entering your full
model number here. It is part # WB36X951.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
SOURCE: How do you install charcoal filter on a GE profile Convection oven.
You can download GE
owner's manuals and installation instructions here.
We're
thoughtful rating of our answer.
