SOURCE: Meat slicer
Goto http://www.hobartcorp.com/default.aspx and call your local branch.Im a service tech for hobart and i can tell you there is ( little if none) these parts are availiable any longer.I will look around for you.
SOURCE: Globe Meat Slicer Model # 500
Fiber gear on blade hub stripped. deep socket required to remove hub. DON'T CUT YOURSELF!! remove motor, used food safe solvent to clean grease out of housing. Fiber gear held on with snap ring. Replace gear, repack housing, put hub and motor back and start slicing. Routinely check to make sure gear is lubed.
SOURCE: model 1101E Rival Food Slicer - grinds to a holt.
Im looking for the nut or bolt that holds the blade
SOURCE: Where can I get a user manual for a Rival electric
Here is a link for manual for all Rival Appliances online and downloadable http://www.rivalproducts.com/help.aspx?helpNav=5
SOURCE: PB switch 681064-01 has 4
Their should be 1 Red, 1 White and 2 Black?
Holding the switch part with the black pushbutton switch to the right. The two wires on the top are Red then White. The two wires on the bottom are both black.
