SOURCE: I have a hp compaq dc 7100, the power supply is
i prety sure there is no way to do that. you might be better off just going to fries or radio shack or some other electronics store and buying a new one, there is no way to change a 20 pin to a 24 pin srry the best pf luck to you. plus i trying to fix my own problem right now
SOURCE: Mackie 1604 Power Connector orientation
Here's a shot of the connector, mated to the motherboard.
SOURCE: Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
SOURCE: I have bought a shower/bathroom extractor fan with
bathroom fans require a mains permenant and a switched wire from pull switch for the timer to work
SOURCE: Parking lights on Nissan Frontier on - trailer
First check the fuses. There may be one for trailer running lights. Check also power at the harness. If the brake lights and turn signals are seperate, there has to be a converter from 5 to 4 wire. For the power to feed back to the brake lights it sounds like the vehicle wiring is direct and not using a converter... or one of the bulbs on the trailer is contacting both contacts. Try http://www.etrailer.com/faq-wiring.aspx and maybe get a simple 4 pin tester that plugs into the 4 pin connecter. Hope this helps.
