Question about Minolta Office Equipment & Supplies
Dialta di450 Error Code C-0500
I have always been able to somehow finagle a fix for our copier, but this one has me stumped...
What does C-0500 mean? How can I fix it?
  • Minolta Master
  • 1,297 Answers
Fuser unit problems.Check fuser lamp in the upper and lower fuser roller,check the termofuse & termistors.
Posted on Jul 30, 2009
Erace the c-of24 on di450
The code refers to a sensor that looks at the drum - it might be dirty or something else is going on check this Fixya-link: Minolta DI450 error code C0F24
Jan 17, 2015 | Konica Minolta Minolta Di450 Di470 Di550...
Di450 Minolta Code 2510 erreur C0000
The C0000 code is that the Fusing Unit (The HOT Part) has a motor and it can not turn or is burned out do jam or gear problems. Could not find anything about 2510
Jan 22, 2014 | Minolta DiALTA Di183 Copier
0500 error dialta cf 2002
open front door lay on your back look for the small hole on the right side touch the small switch with a screwdriver to reset the machine must be on
Jan 16, 2014 | Minolta DiALTA Di520 Laser Printer
Di450 error codes cf033
Hey their... The code on your Hub450/550/470 is the toner density not being read. The drum must be removed u will find a sensor under the Mylar(mylar catches the toner wiped from the drum) that sensor is dirty and the Mylar is bad... :-D. PS u can perhaps repair the mylar with tape from the inside... Good luck
Dec 24, 2013 | Konica Minolta DiALTA Di200 Copier
(C-0500) error code konica di 470
There is a trouble rest button inside the front door above the fuser unit. There is a small panel with one screw in it, remove the cover and you will see a PCB with two black switch's on it. One is the trouble rest button, have the copier ON and press the trouble rest button and close the door and you are done... If it will not rest, check what you did and make sure it is put back correctly.
May 06, 2013 | Konica Minolta Minolta Di450 Di470 Di550...
Minolta di450 error code c0201
please sir, minolta copy di 450 ditected c 133b
Oct 22, 2011 | Konica Minolta DiALTA Di200 Copier
Minolta dialta Di450 Error message C-143E
The Document Feeder has only 1 Malfunction code for any problem with it.
If opening and closing the front cover (while it is turned on) resets it and you can use the machine, dont worry about it.
The unit was prone to this false malfunction code.
If it returns very often, then get an engineer to have a look at it.
Jun 09, 2009 | Konica Minolta DiALTA Di200 Copier
Minolta DiAlta Di450 Error Code C-0072
I NEED THE ERROR NUMBER OR HOW MANY TIMES DOES THE BLINK WHEN YOU TURN ON THE COPIER.
MORE INFORMATION PLEASE ROD
Feb 13, 2009 | Office Equipment & Supplies
Konica CF910
You reset the code by pressing the "Trouble reset switch on the Tech Rep setting Switch board, located under the control panel, open the machine front cover its a small circuit board with two small black press type switches (left side switch)
Jun 19, 2008 | Konica Minolta DiALTA CF910 Copier
Code C-0500 on Di 620
Try opening the front door with the copier on, on the right hand side you will see a small cover held on by 1 screw, remove this and press the reset button then close the door. If the error is still present it will return.
May 18, 2008 | Minolta DiALTA Di520 Laser Printer
340 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
