Question about HP Photosmart C6180 All-In-One InkJet Printer
I am wanting to refill one of my inks and want to know how to do it? I have a refill kit, but my printer is not on the list of printers to be filled by this company. Can I still use their ink or will it ruin the cartridge? Thank you, Denise Anderson
  • 24 Answers
Bad news, your cartridges are one single life, I recommend you buy a kit of refillable cartridges, comes with autoreset chips and yes, you will can use your ink with them, look on ebay there are the refillables even one kit with CISS (Continuos Ink Supply System)
Posted on Jul 29, 2009
    Problem Solver:
  • 17 Answers
I have a hp818 cartridge and I am refilling it at using it since a year. My cartridge was also single use but I wasted it many times after refilling whereas my friends cartridge came up with error after a single refil!! I would say you can try it but it has risk
Posted on Apr 13, 2014
How to refill ink cartridge of Epson me32?
Follow these steps:
1.
Buy an Epson ink refill kit. A refill kit gives you all the tools you need to refill Epson ink cartridges. Kits typically include a syringe, rivets, ink, and instructions on how to refill the cartridge. You can find Epson ink refill kits on the Printer Filling Station along with instructions for each specific model (see Resources).
2.
Cover your workspace with a paper towel and fill up the syringe with the ink color you need. Epson refill kits will either include black ink or the color combination cyan, yellow and magenta. On average, you'll need 10 ml of black ink or 5 ml of color ink for Epson ink cartridges.
3.
Find the rubber seals on the back of the Epson ink cartridge. Insert the rivets into each seal.
4.
Empty the contents of the syringe into the Epson ink cartridge. You'll want to perform this action slowly in order to avoid spilling or overfilling the cartridge.
5.
Remove the rivets. Use tape to cover the holes you made in the ink cartridge. Return the ink cartridge to the printer. Allow the printer to go through several print cycles in order to ensure that the Epson printer operates properly.
In case of any additional help please revert back
Jun 12, 2011 | Office Equipment & Supplies
Red not printing
if replacing M and/or LM cartridges doesn't fix the problem, there is not much you can do. You can try to get the printer serviced, but probably won't find anyone willing to do the job.
LC1000
www.inkbank.com.au
Dec 02, 2010 | HP Photosmart C7280 Printer
I don't know how to refill
Hi Good day!!!
1. Spread newspaper or paper towels on a table to create a workspace protected from spills and accidental leaks. Set the cartridge on this workspace.
2. Remove the label on top of the cartridge. Use a razor to peel up one corner, if necessary, then peel back the rest.
3. Fill the syringe from your refill kit with between five to 10 milliliters of ink. Match the ink to the color listed on the cartridge.
4. Insert the syringe needle into one of the holes on top of the cartridge. If there are no holes in the cartridge, you must create one. Use a thumb drill (also included in your refill kit) to punch a small hole through the plastic.
5. Insert the needle into the cartridge. Inject the refill ink into the cartridge until it is full. Ink will bubble up around the hole when the cartridge is full. Fill the cartridge slowly to avoid mistakes and spills.
6. Place the cartridge back into the printer. Wait at least a few hours before printing. Some refill kits recommend waiting 24 hours before using the printer. Print a test page when the cartridge is ready.
Oct 26, 2010 | Computers & Internet
I have an Epson stylus nx400 printer. I bought the ink refill kits that were recommended for it, but it's not listed on the instructions. I just want instructions on how to refill my cartridges.
Use syringre with small outlet. Fill from bottom side of ink tank. Better you don't refill ink tank. It will distort rubber seal at bottom side of ink tank. Then ink will leak. After refilling, you must reset ink counter. Do you have chip resetter?
Aug 17, 2009 | Epson Stylus NX400 InkJet Printer
Need help with my printer canon MP190
I refilled my MP190 Black cartridge PG-37 by drilling a hole in the top (roughly in the middle) and using the syringe supplied with the ink refill kit. To make the printer work again, press and hold down the Stop/Reset button (on bottom right hand side of printer) for at least 5 seconds until the display reads 1 again. This bypasses the ink level detector and is explained in the trouble shooting section of the on screen manual supplied on the printer installation CD. It works. It then happened again with the colour cartridge, so I repeated the process. It worked again. This should also work for the PG40 and CL41 cartridges.
Apr 20, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Ink refill
You can do a search on Google using "Epson C84 Refill Instructions" which will produce plenty of hits. However, this one gives very clear instructions:
http://www.refillinkcartridges.co.uk/news/2008/10/16/epson-c84-ink-cartridge-refill-instructions/
If you only bought refill ink rather than a refill kit, and don't have rubber plugs, you can successfuly re-seal the filling hole using a small amount of epoxy resin e.g. araldite. This is easy to remove with a sharp knife the next time you want to fill it. Note the need for a cartridge re-setting tool - these can be purchased very cheaply on E-Bay.
Apr 07, 2009 | Epson Stylus C84 InkJet Printer
Ink Jet refilling
the refill kits tell you all about this.
Aug 20, 2008 | HP Office Equipment & Supplies
HP Photosmart C6180 All-In-One InkJet Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
