Question about Kodak Office Equipment & Supplies
Print from a Inspiron 1420 on wireless network
Dear Kodak I am trying to print from a Inspiron 1420 laptop – Vista OS to a Kodak 5500 AiO, wirelessly. My
other computer is a Vostro 1400 laptop – Windows XP OS. I am running a Linksys WRT54G router
on my network. The printer is connected to the Vostro laptop via USB. I can print from the Vostro
but not from the Inspiron computer.Thank You for your helpTed Schank
tds789@hotmail.com
  • tds789 Jul 30, 2009
    Dear saiki006
    There is no USB connection on the back of my LinkSys WRT54G router. On my printer (Kodak 5500 AiO) there is no "Network Settings: setting to scroll to. My printer is connected to a Vostro 1400 laptop via USB cable and works fine, but I can not share it with the Inspirion 1420. The Vostro is connected to the router by hardwire and the Inspirion is connected WiFi.
    Thank You
    tds789
    No, there is not a blue tooth adapter installed on the printer.
  • 453 Answers
If you have a USB connector on your router, it should work, but you may have to look at your router documentation for the setup. You will need to install the printer drivers on each machine in the network to use the printer.
You must connect the printer to your wireless network using the printer control panel WiFi Setup Wizard before you install the All-in-One Printer Software on your computer.
When you connect the printer to your wireless router, you need to know if your SSID (network name) is being broadcast. If your router's network name is set to broadcast, the printer control panel wizard will display your SSID when you scan for networks. If the SSID broadcast is disabled on your router, you must select Unlisted network on the printer and manually enter the SSID to connect. Do the following to set up and install the hardware and software.
Connecting the printer to your wireless router:
  1. On the front panel of the printer, use the 4-way navigation button to scroll to Network Settings, then press OK.
  2. Scroll to WiFi Setup Wizard, then press OK.
    "Searching for wireless networks..." displays, followed by a list of wireless networks that are broadcasting within range of your printer.
    NOTE: If the all-in-one printer was previously connected to a network, "Your printer is already configured for WiFi network [name of network]" displays. Press OK to change the settings.
  3. Scroll to the desired SSID (for example: Home Network 1), and press OK.
    Using the 4-way navigation button and the OK button, enter the alphanumeric characters of the network key that exactly matches your wireless router key or password (for example: NewYork82655). Navigate to Done, then press OK.
    NOTE: The password is case-sensitive. Click abc/ABC to switch between uppercase and lowercase characters as necessary.
  4. Scroll to View Network Configuration, then press OK.
  5. Use the 4-way navigation button to view all the information and verify that the Network Configuration settings -- including Printer Hostname, IP Address, MAC, and SSID -- are populated and accurate.
  6. Press Cancel or OK to exit the View Network Configuration screen. The Network Settings menu displays.
    The Wi-Fi Status Light should now continually illuminate, indicating that you have a good connection between the printer and your network.
Installing the printer software:
  1. Insert the CD into the CD-ROM drive of your computer.
    The Install Wizard - Welcome screen displays.
  2. Click Next.
  3. Select I accept the terms of the License Agreement, then click Next.
  4. Select Essentials KODAK All-in-One printer software, then click Next.
  5. Click Next. The "Choose the registration level" screen displays.
  6. Select the option you want, then click Next.
  7. Select Yes, then click Next.
  8. Wait while the software is loaded.
  9. Select Connect via Network - Wireless / WiFi, then click Next.
  10. Click Done.
  11. Click Continue.
  12. On your WINDOWS Computer, click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
  13. Right-click the wirelessly connected KODAK ESP 7/ESP 9 AiO Printer, and then click Set as Default Printer.
    NOTE: If the system does not find your wireless printer, you may have to manually allow inbound and outbound permission through your firewall for certain required computer services.
Posted on Jul 29, 2009
  • Sai Kiran Camsarapalli Jul 30, 2009
    I would like to know if a blue tooth adapter is installed to the printer.
    If yes, then I would like to let you know that the printer is not wireless enabled. The printer can pick up signals from a wireless device like Mobile phones/ PDAs/ Cameras(Bluetooth enabled) in a short range and cannot pick up signals of that of a wireless router.
    http://www.kodak.com/eknec/PageQuerier.j...
    The information about the wireless bluetooth can be found in page 41 of the manual. The link to the manual is pasted above.
    Yes if there is no blue tooth adapter then you need to install one so that the printer can be wireless enabled.
    Otherwise the printer has no other option to connect wirelessly.
    Bluetooth wireless can be enabled to connect to only other bluetooth enabled devices like Mobile phones,PDAs and Digital cameras.
How do you make the Kodak 5500 cap of wireless printing?
Bluetooth adapter wil only allow you to print photos wirelessly.
If you want to connect through wi-fi please contact kodak and ask for "SILEX".
Nov 14, 2009 | Kodak ESP 5 Printer
Got aio kodak 5500 printer hw to print wirelessly,
The Kodak 5500 AiO Printer has no WiFi functionality and thus will not work wirelessly
Oct 21, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have a Dell Inspiron 1420 that has a Microsoft Windows Error message that will not go away even when closed. It says "Dell Wireless WLAN Card Wireless Network Controller stopped working and was closed"....
Try Deleting the wireless card from Device Manager.
Beware though, if you do this all your wireless settings, such as network names and keys,will probably be deleted as well.
Then right click on the name of your computer and click scan for changes and that will then reinstall the card. Can't say it will help but it's woth a shot.
Oct 06, 2009 | Dell Inspiron 1420 Notebook
No wirelesss network adapter or sound after installing Vista
Most likely the drivers aren't installed. Go to the product page for your computer and download the appropriate drivers for your OS.
Aug 02, 2009 | Dell Inspiron 1501 Notebook
Wireless printing
not possible... kodak all in one esp-7 and esp-9 support wireless printing. what u can do is, u can connect ur printer and computer through usb cable and then give a print command from ur computer. be it internet or any document on ur computer. kodak printer will give u high-quality prints,but ur printer does not support wireless printing.
Jul 28, 2009 | Office Equipment & Supplies
Cannot add printer to PC on network
heres a link for drivers for your machine.....download the proper driver for each individual system and run setup application
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9106&product=EKN033540
Apr 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
I have a new Kodak ESP 7 printer and have not been able to set it up to communicate with my Mac OS 10.5 laptop. I can print if I have it plugged into the USB. I understand I might need an extra unit to...
Hi. I can help you connect your wireless ESP 7 to your Mac laptop.
The first step is to connect your printer to your wireless network. Navigate to the menu on the LCD of the printer and select Network Settings/WiFi Setup Wizard. The blue WiFi LED should be illuminating steady if the printer is connected to your WiFi network.
The second step is to add the WiFi printer to your Mac using the Print & Fax System Preference...
1. Under the Apple Menu, select System Preferences
2. Select Print & Fax
3. Click the "+" sign to add a printer
4. Select the Kodak ESP 7 listed with the Bonjour connection
5. Click the Add button.
The final step is to verify that you are printing to the WiFi printer when you attempt to print. In the Print Dialog box, verify the selected printer is named "KodakESP7+1234" where the last four digits are unique to your printer. If the printer you have selected is "Eastman Kodak Company KODAK ESP 7 AiO", then you are attempting to print using USB and this will not work unless you have a USB cable connected.
I hope this helps.
Dec 04, 2008 | Office Equipment & Supplies
Wireless print device server
Yes.
The print servers really don't care what kind of printer is connected to it.
They are simply a device that carry signal from your computer to the printer.
Jul 30, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Video display with Kodak AiO Home Center
Make sure that your screen resolution is 1024x768
Jun 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
81 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
