SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12
mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to
gather around on the sofa at home or slip into a carry case for when on
the go".
Archos Arnova 10 G2
this means that the program you were running has crashed. If it happens everytime you launch a particular application then I would advise removing the program from the tablet and then reloading it
SOURCE: how do i remove the password on my 7 inch tablet android
After trying password for 5 times, it shows a "forgot password" option. Click on it. Provided the gmail id and password you first used to logn into your tab. It will remove the password from the device thus unlocking it.
SOURCE: I have an android tablet, YouTube works but when I
If you updated your operating system you may need to go and turn the auto rotate back on under options.
