Question about Microsoft Windows XP Professional for PC
Lisencing What kind of window xp license type should i buy ? if can activate only one time, and then if my was attacked by some virus. and then i can not re-install buy using this key anymore. cuz it is already was activated and used already. i have to buy one more. to me the windows xp license is quite expensive. any idea ?
    Problem Solver:
  • 9 Answers
Re: Lisencing
DON'T use someone else's key. It's against the law and eventually the key will be blacklisted. This means that you will lose access to Windows Update services.
I don't like copyright protection on software and I personally think that software licensing and software protection is both harmful and cumbersome for its users. This doesn't change the fact that legally, you are required to license Windows. Go with Windows XP Professional if you can. If you want to try Windows Vista, you will need to do some research into which version is appropriate.
If you want to Hack Windows or use someone else's registered key, you are committing a crime and this forum is not the place to find help. You'd be better off Googling it.
I don't mean to sound like a "ninny", it's just posts like the previous one that get sites like this shut down.
Posted on Nov 24, 2007
Re: Lisencing
Ya i have an idea keep this licence and you dont need to buy it any more...PB9TV-426P7-D9FKW-8K9JD-43VKT
have this key forever
Posted on Nov 23, 2007
0 characters
3 Points
MY PC does not have geniune mircrosoft, but now i have a note which pops up on my desk top to ask for geniune microsoft. Because of this I have problem openning my word documents they are all encrypted....
You either have to download and use a "Crack" or "Hack" and illegally do it, or buy a licence from Microsoft? One "Hack" is WGA removal tool, simply Google for one and download it and install as per instructions.
Oct 13, 2011 | Microsoft Windows XP Professional for PC
Activate xp home with sp3? without buying a license that is.. ; ) so any good 1s? really need 2 activate my xp home within 2 days, i skipped the step with the serialkey when i was installing..but now i am...
Reinstall Windows, entering the license-key when requested, instead of skipping that step.
Or, try to "activate" it -- it may ask you to enter the license-key.
Jul 16, 2011 | Microsoft Operating Systems
This copy of Windows did not pass genuine validation
If you see this illustration :
This means, your Windows XP is not license,If you want this notification be remove, just download the link below :
Here is the instruction :
* after downloading the file,extract it even on desktop.
* if you want to add license on your Win XP,go to "Magic Regfile" folder then click the application to operate
* if you want instant genuine XP (just a patch) open "Remove WGA"folder and with just one click with that application,the notification will be remove and your window XP is now genuine.
If you don't have sufficient money to buy genuine XP, this is the alternative way to use your computer or laptop.
Hope this solution helps...thank you for visiting Fixya....
Jun 13, 2011 | Microsoft Windows XP Professional With...
Unregistered windows xp, I have the key how do i register it
How to activate Windows XP by using the InternetTo activate Windows XP by using an Internet connection, follow these steps:
  1. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click Activate Windows.
    Or, click the Windows Activation icon in the notification area.
  2. Click Yes, let's activate Windows over the Internet now.
  3. Click Read the Windows Product Activation Privacy Statement, click Back, and then click Next.
  4. Use one of the following methods:
    • If you want to register and activate Windows at the same time, click Yes, I want to register and activate Windows at the same time, click Read the Windows Registration Privacy Statement, click Back, click Next, type your contact information in the appropriate boxes in the registration form, and then click Next. An asterisk (*) appears next to required information.
    • If you only want to activate Windows, click No, I don't want to register now; let's just activate Windows, and then click Next.
    The wizard establishes a connection with an activation server, and then processes the activation request.
  5. When activation is completed and you receive the following message, click OK: You have successfully activated your copy of Windows. *
Feb 28, 2011 | Microsoft Windows XP Professional
I had a tech work on my computer some time ago and now I'm getting a message from Microsoft saying that I don't have a genuine windows license. The tech is not longer in business. Can you tell me how to...
You can only correct this if you have the original license key before you took it to the tech guy. You need to activate the key on Microsoft site after entering the key in your Windows XP system. But if you can't get this key you may need to buy another license key from Microsoft.
Jul 15, 2010 | Microsoft Windows XP Professional
Weird folders appearing
those all are garbage folder, which are generated as a result of virus attack on your system, i strongly recomend you to format your main drive and reinstal the windows and this time also instal a powerful antivirus
Nov 05, 2009 | Microsoft Windows XP Professional
check for activation status of your AVG, & also get updates for the latest virus definition updates, the scan the system, it works.
Mar 23, 2009 | Microsoft Windows XP Professional
may be it is a keylogger which is attacked to your system so you couldnt able to type ...
or may be the bios is unable to detect the keyboard ..
once you remove the keyboard from the port and put it back again that may work have a check with this ...
or the wire might have broke down just have a check ...
if all are right then it s the keylogger which is attacked to your system ...
so you must format the system i think your keyboard will work at the time of bios ... so can format the drive containing OS from booting with the windows xp boot cd .....
after formatting you can install the new copy of it ....
any doubts you can reply me
i am always here to assist you
thank you
bye .....
rate my solution
Jul 11, 2008 | Microsoft Windows XP Home Edition
Hello please i would like to get from you a windows xp home sp 1a product keys
Dear princebaraka,
I believe that kind of question isn't allowed. We can not offer you/give you a legitimate Windows XP Home Edition Serial Key. The reason is simple, it's illegal. There are plenty of websites that store serial keys but the thing is, those are probably already blacklisted and do not allow you to update your computer. Which off course is a big security risk.
There are alternatives though to get Windows XP pretty cheap.
1. Buy a new PC with XP. Usually you'll get an OEM license.
2. If you are still a student, maybe your school has some interesting offers for it's students.
3. Use a serial key from an older PC. Install XP using the software disc you have and if it cannot activite because of the hardware being to different from the PC Windows was activated on you'll need to call Microsoft (phone number is on the Activation Utility)
That's all I can do for you.
Jan 25, 2008 | Dell Microsoft Windows XP Home Edition
Microsoft Windows XP Professional for PC Logo
67 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
