Question about AEG MCC663 Microwave Oven
Grill element stopped working.
Unit is 5 years old. 1 year ago the grill element stopped working. I unsucessfully tried to remove it. However the element started working again and I assumed there must have been a dirty contatct. The grill element has now ceased working. Everything else works fine and when you turn on the grill all lights work and turntable turns. Is there a relay which may be faulty? If it is the element how easy is it to change and how do you do it.
I had the same. Dismantle the oven and see at the back side the connection wires for the heat element. Mostly one of the connectors is faulty. I fixed it that way.
Posted on Jan 16, 2010
How do I use the grill function on my new microwave?
I've had an Emerson microwave/grill for about 5 years now and love it!! To use the grill function you just hit "grill/combo" then hit the buttons up above the grill/combo button for however many minutes or seconds you want, then hit "Start" button. make sure your using a metal dish.
Feb 20, 2016 | Emerson Microwave Ovens
We have a 3 year old Cooke and Lewis integrated microwave/grill that has recently stopped working. It starts up but after 5/6 seconds it stops and 'err 5'comes up on the display. Any ideas?
if this was purchased from the likes of B&Q, at the time of purchase, the retailer must ensure that the goods are/were fit for purpose for a period of 6 years from date of purchase. This is regardless of manufactures warranty. Take it back, demand a new one, quoting the above
Jan 02, 2016 | Microwave Ovens
Unable to find replacement grill vent cover
are u talking about the mica looking thing inside if so let me know
Apr 01, 2013 | Microwave Ovens
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
I have this inter-grill' not quite sure the spelling, over 1 year old. It is doing everything except heating. timers, lighting etc are ok including inbuilt grill. pls advise
This is happening due to either the magnetron, or the Power Diode, or both, is breaking down, under load, then the unit detects the fault condition, & then, shuts the magnetron down, for safety reasons, to avoid a fire or explosion, so, it shuts down the MW system. You need to take it in to be looked at please obtain a "Quote" before proceeding with any work. This way you can decide to repair or replace
Aug 06, 2010 | LG Microwave Ovens
I was heating up some left over for 1 min. and before completion the microwave just stopped. I have tried all of the usual stuff to get it going again. It is not the electrical socket nor the fuse box...
It could be as simple as a blown fuse inside the unit. They are usually ceramic type fuse not glass, so you need a meter to check it or you can try to replace it and see if it fixes it. Please use only a fuse of the same type and amps! The unit may blow the new fuse, which would indicate a short inside... you''d need to call a repairman. Lastly check your warranty dates, if under a year you may have some coverage. Hope that helps.
Geno
Dec 06, 2009 | Emerson Microwave Ovens
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Aid (KA) Over stove Micro - vent grill plastic brackets
My grill has also fallen off twice. It usually results in the tabs breaking off. My solution has been to add tiny (1/2" x 1") shims in the slots where the tabs have broken. Look carefully. There are two tiny channels. I wedged the wood in and then reattached the grill using sheet metal screws in the same screw holes. It won't come down again. In three years since doing the kitchen with all KA appliances we have replaced the grill once. We had the stove removed and replaced by the appliance company at no charge after 4 months. We had our ice maker replaced out of warranty. I would never recommend KA appliances to anyone. The quality is absolutely terrible.
Mar 22, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
GE Profile Microwave oven
ge microwave fuses are behind upper grill and behind right side grill
Jul 25, 2008 | Microwave Ovens
AEG MCC663 Microwave Oven Logo
287 people viewed this question
Top AEG Microwave Ovens Experts
William Miller
William Miller
Kazim ERGUNEY
Kazim ERGUNEY
Raj Patel
Are you an AEG Microwave Oven Expert? Answer questions, earn points and help others
