Question about Mantis 7225-00-02 2 Cycle Gas Power Cultivator
PRIMER GAS BUBBLE CRACKED & LEAKING - Mantis 7225-00-02 2 Cycle Gas Power Cultivator
  • 376 Answers
Carefully unsrew the two screws in the plate holding the primer bulb down and just remove it while holding the rest of the carb down. Take the bulb to a parts/repair shop and buy another bulb for a Zama carb and reinstall.
Posted on Jul 29, 2009
Gas is leaking from the primer on my swisher walk behind trimmer. What would cause this?
i believe you have a cracked primer bulb or cracked fuel line. you should also check and see if the screws are loose that connect the primer bulb to the assembly.
Sep 25, 2013 | Swisher Walk-Behind High-Wheel String...
Primer bubble dose not fill with gas
is it cracked and are the fuel lines going to it cracked
Aug 25, 2012 | Echo Pb-403T Leaf Blowers
I have a 124l e-tech trimmer and the prime bubble wont fill
Sounds like you have an air leak. Either in the primer bulb is split or punctured, hole or leaking fuel line or primer bulb base, and is sucking air instead of fuel.
Aug 20, 2012 | Husqvarna 124L 28cc Gas Line Grass Lawn...
Gas leaking around back handle at throttle control
I had a homelite that when you pulled the choke out it pulled the fuel line off of the primer bubble. If your primer is at the back of the saw, check the lines for holes or just pulled loose.
Mar 02, 2011 | Garden
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
Is there a gasket under the primer bubble;it won't **** up gas
the pick up tube in the fuel tank is probably bad
Sep 16, 2009 | Garden
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
Mantis 7225-00-02 2 Cycle Gas Power Cultivator Logo
489 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
