Question about Jandy Lite 2 Natural Gas Pilot Light Heater
FL 4 error, Jandy Lite 2 pool heater
FL 4 error
heater clikcs like it's going to fire up, but it doesn't then FL 4 flashes
  • 21 Answers
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
Turn off the stove. Seriously. If my stove is on there isn't enough gas pressure sometimes for it to light.
Posted on Jul 24, 2012
    Champion:
  • 246 Answers
Check the gas valve if is open
Posted on Aug 25, 2009
I have a jandy lite 2 pool heater, fl 2 error appears even though flow seems ok burner wont fire. should the pressure switch be replaced.
FL2 means igniton failure that means the heater didnt lite make sure gas is on, is the ignitor glowing if not check the fuse on the red wires going to the ignitor sometimes the syphon loop gets plugged that will give you a flow issue
Sep 01, 2014 | Pool & Spa
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Jandy lit 2 heater error fl 6
gas signal being sent to gas valve not by controller either stuck gas valve or bad control board
Apr 14, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
FL 4 code Hot surface igniter problem on Jandy Lite 2 - FixYa
check the fuses from the red wires if blown replace if ok replace ignitor
Aug 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I have a Jandy Lite 2 heater and I keep getting an error message FL 0. What can I do to get this heater working?
check the copper line to the pressure switch if ok check pressure switch should have 24 volts ac both sides if ok check rest of safety circuit
Aug 26, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy heater not starting
FL 4 is igniter failure.
1. check the fuses on igniter wire as well as the wires.
2. replace igniter
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
2,322 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
