Hi, Just replacing an existing oven with a new Neff U1722 oven. they don't show the electrical connections in the intallation book, nor indicate which is live and neutral on th appliance, i think the Live is the terminal with black internal wiring? can you help please? Eamonn
Comments:
Nov 23, 2007
- Many thanks Cerf Neutral is blue Live red or black here.. Cheers
Use your original wire and hook up Left to right Line Neutral, and Ground. L N G. Black wire is Line. Green wire is Ground. not sure what UK uses for Neutral. I just know that you need a big wire. And the voltage is supposed to be 220-240Volts.
Hellow!
I `d like to buy mold heater for our five silicome injection mold, the base spec is:
1,...
(More)
Hellow!
1, diameter 12mm
2, length from 360 to 550
3, 600w to 1400w, Sanyo brand.
4, I am in Shang Hai, China
Would you please intoduce someone or some places to me so that I can buy them ASAP?
Best regards,
Bruce Tao,18721150846
Hi, I have a frigidaire 27 inch wall oven and every time I use the cleaning cycle the oven quits...
(More)
Hi, I have a frigidaire 27 inch wall oven and every time I use the cleaning cycle the oven quits working. I have had it less than a month and the tech that came out to fix it said it was a common problem and that all I need to do is pull the oven out, remove the back panel, and hit the reset switch. That is crazy. What do you think.
Beko DV5531 instuction manual needed urgently as my friend cant get oven off of AUTO so unable to...
(More)
Beko DV5531 instuction manual needed urgently as my friend cant get oven off of AUTO so unable to use main oven
