Question about Magellan Triton 400 Handheld GPS Receiver
Hold in the power button and won't start. I have changed out the batteries to no avail (Yes, made sure they're installed properly
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 154 Answers
Two possibilities. One of the power button leads are disconnected or you should reinstall the latest firmware again.
.. or go to Jungleghost.com and use their repair center if the unit is not in warranty.
JG
Posted on Nov 14, 2009
Starter versus alternator for reasons 1997 jeep won't start - battery OK
yes, could be ! change your fuel & air filters , its winter time , yes !
Jan 25, 2013 | Cars & Trucks
Lap top won't come on
Follow the steps below and it should solve your mac problem..
  1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the fluorescent pen computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the PowerBook G4 Battery 15" power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter,learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the sony vgp-bps13a/b battery power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the sony vgp-bps13 battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
  10. If you are still unable to start up your computer after trying each of these steps, schedule a service appointment with either an Apple Retail Store or an Apple Authorized Service Provider.
Regards,
Ron
Jun 02, 2011 | Apple 13" MacBook Notebook Computer ...
How do I switch on my 3109c
Look at the top of you mobile, you'll see a button (there's only one button) with a circular power symbol, Press and hold down the power button, it should start up. But before this, make sure the battery is charged and properly installed, otherwise it wont power On.
Let me know if you need further help..
Good Luck.
Thanks for using FixYa.
Apr 07, 2011 | Nokia 3109 Cellular Phone
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Networking Trouble?
Make sure you are using the USB cable that originally came with the Walkman. Make sure the hold switch is not turned on.
Reset the player.
Try charging using another USB port on your computer - if that fails, try charging on another computer completely (but make sure it has the same OS or you will experience formatting- related issues).
My general info sheet: 1.       “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE)
The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Many laptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button.  There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard.
Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue.
If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this.
Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.”
If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components.
If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced.
-Tha Mp3 Doctor
Sep 14, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Mp3 player
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)
Here's some general info about the problem: 1.      1.       “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE)
If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Sep 06, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Digital media player
Make sure the hold switch if off. Reset the player. Try a different USB port on same computer. Try a different computer with the same OS (to prevent formatting-related errors)  Here's some general info about the problem:  “My Mp3 player won’t turn on” or “My Mp3 player won’t hold a charge.” (POWER SUPPLY ISSUE) The tricky part about these issues is that there are several possible causes – it could be software or it could be hardware.  Before you try anything else, make sure the mp3 player’s “hold” or “lock” switch is not engaged.  See your user’s manual for location of switch/ instructions (available from manufacturer’s website).  If the hold is engaged, the mp3 player will not charge, and it will not turn on.  Then, make sure the player is plugged into a compatible computer with a USB 2.0 port.  Manylaptops and older desktops lack sufficient power resources to properly power/charge/utilize an mp3 player.  Next, try resetting your mp3 player.  If that still fails, try your device’s “recovery” button. There is a specific button that triggers the recovery mode – volume + for most players, REC button for others, play for others, and skip forward for still others.  The general formula goes something like this, although you may have to substitute another button for “volume +”: disconnect the player from the computer, turn it off even if you have to reset the player to turn it off (if it is dead, this won’t be a problem), hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player (even if it is completely dead) - it will pop up a window that says Found New Hardware Wizard. Make sure that your mp3 player is not designed for a country other than your own – this information can be obtained from the manufacturer in most cases.  European and some Asian current systems are different than in the U.S., Canada, and Mexico.  If you plug a United States mp3 player into a European wall outlet, you will fry the player.  If you plug a German mp3 player into a US outlet, it will have insufficient power to power the player.  There are transformers available that can correct for this issue. If you have lost the original charger for your mp3 player, try to obtain the original charger.  If the original is no longer available, check your product specs to get EXACTLY the correct voltage.  It may seem harmless to use a 5V charger on a 4.5V mp3 player, but in many cases you will damage the mp3 player by doing this. Also, never unplug an mp3 player while it is transferring music/files/performing a firmware upgrade (and also, never perform these activities when your player is not at least 75% charged).  This is a sure way to kill most mp3 players.  As a safety rule, always check and use the “safely remove hardware” option if it is available on your computer – lower right hand corner (green arrow pointing to chip) in most Windows taskbars.  If it is not available, wait one full minute after your last file transfer to unplug the mp3 player – even if your mp3 player says “OK to disconnect.” If your mp3 player uses AA, AAA, or any type of user-removable battery, you must take extra steps to prevent equipment damage when replacing batteries (most product manufacturers do not know this tip).  Before removing the batteries, power the player off and let it sit for one minute or longer.  Run your hand along the side of your computer tower to dissipate static electricity (or use any other method available to dissipate static electricity).  Use only and exactly the replacement battery recommended by the manufacturer.  Carefully remove the old battery.  Hold and gently squeeze the new battery for a few seconds to dissipate static.  Hold the mp3 player case in one hand, and carefully insert the new battery.  One single static spark, and your mp3 player could be history.  Also, check your product documentation beforehand to see if removing the battery will result in your song’s being erased/data being lost.  Many, if not most, mp3 players do not have replaceable batteries – the manufacturers do not have them, and popping open your mp3 player more often than not causes damage to additional components. If the solutions above do not work, and you have gone through troubleshooting with the manufacturer, you may have hardware damage and the player will need to be replaced. -Tha Mp3 Doctor
Aug 12, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
It wont charge
Jun 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
The songs on my mp3 will not play. They appear on the screen but no sound. THere seems to be trouble with the battery.
Jun 03, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Sony help
Jan 29, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
Magellan Triton 400 Handheld GPS Receiver Logo
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
