Question about Samsung Televison & Video
I have a Samsung 1080p, version PH01, model number HLT5676SX/XAA. The T.V. won't turn on. All the lights under the stand by/temp/timer are flashing continuasly.
  • Samsung Master
  • 5,807 Answers
first check the cables at the back and securely it firmly.
then power it on again, if still the same problem, try to use video input
power it on again, if still the same problem, here are the possibilities
a) if using TV mode, maybe there is no signal going in the antenna terminals
b) if using input mode,
check the connecting cables and secure it firmly
One reason why your TV blinks is that it is now in protection mode.
It is protecting itself from further damaged, it might not turn , till the fault is repaired and corrected.
my suggestions:
1) there might be electronic components failure
here is the guide:,
have a visual check on the main circuits board,
look for , there might be bulge capacitor
if visual check wont work, a multimeter might do the job
you need to get the B+ or someone who knows something about voltage checking
It will all start with B+ - the main supply
a) the secondary section of the chopper transformer has shorted diode-- have it checked
or have busted capacitor, if OK
b)the trouble is on the primary side of the chopper transistor--have a checked on the zener diode, capacitors, diodes, resistors
c) the inverter circuits might be misbehaving.
if the unit is still in warranty period, give a ring on the dealer or visit the manufacturer web site.
these are just my suggestions, hope i have helped you, thanks for using Fixya!
Posted on Jul 29, 2009
Samsung DLP Flashing Lights
Make sure lamp is in correctly and as far as the color wheel: The ribbon cable from it to the DMD box only has connections on one side where it plugs in---it is possible to put it in backwards and set will detect wheel is not working..............
Jun 14, 2012 | Televison & Video
Samsung Flashing Lights
a new lamp is possible or even the ribbon cable from the wheel to the engine may be in backwards.
I don't have the manual for my Samsung DLP projection T. V. but my stand by/temp red light blinking come on then go off, along with the timer green light come on please tell me why i do not h
Samsung= Lamp is customer replaceable-----Google the HLS5086 (forget the WX etc) for "manual" and if you remove the lamp(very easy) look to see if the lamp is shattered inside---
You Tube has lots of videos by model and brand for lamp removal and replacement--if you need advice about this leave a comment here.
Apr 19, 2012 | Samsung Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
Samsung model HLT5676SX wont turn on and has three flashing lights''
Replaced the lamp. This is the most common root cause of the flashing lights. PN: BP96-01795A
Mar 15, 2010 | Samsung Televison & Video
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
My screen is cract
Call the following number to know part price, availability, and delivery cost: 1-866-925-PART (7278)
Dec 15, 2008 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
178 people viewed this question
Henry  Thomas
Henry Thomas
