Question about Citizen Watches
Citizen skyhawk c651 .analog UTC not match digital/good set up/,batt 3 bars,0 position works ,hands moved.dont find anything on this subject/problem on manual/set up time.any advise/help?thank you
SOURCE:
SOURCE: UTC hour hand off
I tried this on my C650 with success:
http://www.fixya.com/support/t468199-setting_model_number_jr3060_59f
Posted on Jun 17, 2009
SOURCE: I can't get the clock hands to correspond with the digital time.
You must set the "Zero" position for your watch. Follow the instructions at this address and your problem should be corrected.
http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Good Luck
Posted on Jun 23, 2009
SOURCE: My Citizen Skyhawk Eco-Drive JR3000-51F Wrist
I had the same issue, and was able to reset it doing the following:
1. I let it recharge for at least a day in bright sunlight
2. I turned the selector to "CHR"
3. I pulled the crown all the way out.
4. I held both buttons down for 5 seconds (don't know if this was what did it.
5. I pushed the crown back in.
It did some funky hand movements stuff and then started off working.
Posted on Aug 27, 2009
escapement
  • 2338 Answers
SOURCE: once time is set digitally, the analog adjusts to
Find your Citizen manual in my tips. When visiting the site use interactive settings.
Posted on Jan 26, 2010
davemaurer
  • 84 Answers
SOURCE: Citizen Skyhawk SMT date?
You've gotta go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) or ON (for summer time). According to their website FAQ, they can't determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. Disappointing, I know. I just spent half an hour going through their website looking for some master switchover as well.
Posted on Nov 17, 2011
I am having the same problem as some with my local and UTC times not matching. I have performed the 0-Position correction, but my UTC minute hand is still off by about 10 minutes from my local time. When...
According to the FAQ on citizenwatch.com, the hands are repeaters of the digital time. If you do not have the ability to adjust UTC independently on the digital readout from your local timezone, your watch probably needs service.
Sep 15, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
I have the correct time set in the watch, the main analog clock shows the correct time, but the UTC analog hands19:00 when the UTC digital time is 12:00. How do I reset the UTC analog hour hands?
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
BTW, I love my Titinimum Skyhawk
Aug 03, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
My Citizen Skyhawk analog UTC hour hand is alway 1 hour ahead of the UTC digital hour. I've tried reset and the hour/min hand alignment process without success. Any ideas other than sending in the watch...
Mar 27, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
How to set the time for citizen eco drive skyhawk.
Hi, This watch is Calibre C651, same as Model #JR3090-58M (Promaster Air Collection - Blue Angels Skyhawk). C651 is not available on Citizen website, but you can use Calibre C650 instructions. Download PDF manual and follow instructions on page 3. They are pretty detailed, so take your time, and you should be successful. If you don't have the manual, Try this link:
http://www.citizenwatches.com.au/instruction-manuals
Take the four-digit Calibre number (C651 or C650 in this case) from the back of the watch, enter it, and download a PDF of your watch setting-instructions/manual.
I hope this helps you. Thanks, Bill
Sep 06, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Utc Dial does not match Digital utc readout and I can't for the life of me figure out how to sync them
I finally figured this out... You must zero all the hands by setting the mode to CHR and pulling the stem to the second stop. Go through the process of setting the hour and second hand to zero. The secret is that zeroing the MINUTE hand also controls the UTC display zeroing. You will have to crank it until the UTC display reads 0:00 (24:00). Then go back and set the time and so on as usual.
May 11, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Good Luck
Jun 18, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
24 hr utc display is not synchronised with the rest of the watch.
Here is the link to get full instructions how to set or reset your watch (paste it into your browser):
http://www.citizenwatch.com/CUK/English/technicalinfo.asp?caliber=C650&ModelNumber=JR3060-59F
Choose: Interactive Settings Instructions.
You need a pair of speakers or earphones connected to your PC as all instructions are visible and audible.
Do not forget to rate, please.
Jan 06, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watches Logo
744 people viewed this question
Top Citizen Watches Experts
Arturs Kalnins
Arturs Kalnins
Felipe Valera...
Level 1 Expert
Are you a Citizen Watch Expert? Answer questions, earn points and help others
