Question about Refrigerators
Refrigerator doesn't cool at all on any setting, but the freezer section is working fine. This is a model 253.8795220. This is 2-door style where freezer is on top and refrigerator is on bottom.
  • davis_dot Jul 29, 2009
    I won't know if the suggestion solved the problem for a few days. A little troubleshooting will be involved. Will let you know.
    President:
  • 2,559 Answers
You need to check the defrost timer,defrost element,and defrost thermostat,one of these are not working.Most likely the timer
Posted on Jul 29, 2009
  • 1122 Answers
SOURCE: Hotpoint top freezer HTS18GBMBRWW
CHECK FREEZER FAN,CHECK FREEZER DRIAN IN BACK OF FREEZER IS NOT FROZE,CHECK DEFROST TIMER TURN CLOCKWISE TILL CLICK FAN SHOULD COME ON,THANKS-MIKE
Posted on May 29, 2008
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
SOURCE: Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Posted on Mar 23, 2009
jumptrout51
  • 3361 Answers
SOURCE: freezer is not cooling at top - ice melted -not
Check the back wall of the freezer for a ice buildup.(failure to defrost)
Check the freezer fan motor. Is it running?
Posted on Feb 12, 2010
heatman101
  • 43501 Answers
SOURCE: Hotpoint htr17bb Top Freezer Refrigerator Freezer working, but refrigerator not cooling
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
The freezer section of my whirlpool double door refrigerator becomes too cool while refrigerator section does not cool lower than 56 deg F. Setting of Freezer section is at minimum cool (extreme left)...
when you open the freezer door you should hear a fan running, that's what cools your refrigerator section. If you don't hear that fan, that may be the problem. Also if there is frost on the back panel of the freezer that also may indicate a defrost problem, which could cause the same problems
Aug 22, 2010 | Refrigerators
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Aug 10, 2010 | Traulsen Reach in Freezer - G22010
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
Jun 11, 2009 | Jenn-Air JFC2089HE French Door...
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Kenmore upright freezer.
Will need a little more information to assist you with answers. Will need the model number if available for you Kenmore and will usually be on inside Freezer/refrigerator door and near bottom. Will look like model #363.1234567 for example.
Now if it's not cooling at all, is the compressor running beneath the fridge? Is the condenser fan running that is below the freezer and near the compressor? Is the evaporator fan blowing air in the freezer section? Do you hear clicking noises in the compressor area and can you feel the compressor to see if you feel warm or hot to touch around its side and top? Can you tell me of any other things that you noticed before the refrigerator stopped working? Is the temp control digital or manual settings? Has the settings been changed since you turned the refrigerator off and then back on? Thanks, Sea Breeze
Oct 28, 2007 | Freezers
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
