Emachines W6409 restarts over and over
I have an Emachines W6409. It has worked well for me over the past couple of years, but all of a sudden a cuple days ago, it restarted itself and it gets to the loading bar page, and does it again, over and over, never making it past the darn loading bar screen. Ive tried safe mode and norman, no difference. Can someone help please!?!?
  • michael_s_mo Jul 29, 2009
    im sorry but i dont exactly know how to get to the recovery console. can you explain it to me?
  • dewey wyatt May 11, 2010
    try and see if you can get to the recovery console by booting from the disk. if you can try "fixboot" & or "fixmbr" and see if it helps. sometimes it will and sometimes it won't. you still have the option to restore. you are missing a file needed to boot if you can get the name you could do it that way too. hope this helps if not post back and we will try something else
  • 4 Answers
I have the same computer and it has the the same exact problem. I was told it was the power supply
Posted on Aug 24, 2009
    Scholar:
  • 86 Answers
If you haven't messed with anything inside the case lately, go in with a can of air and remove any dust particles, etc on the motherboard and other components.
If there is no loose wires touching the cabinet or other things inside. Or no dust is thickened to cause the problems. It could be a corrupt file in boot sector. Do you have recovery disc? Unfortunately, it may be the only to recover this computer is to reinstall. (losing all data).
But its hard to say, it could be several things causing your issue. Hope this helps. Good luck!
Posted on Jul 29, 2009
I recently purchased Two PNY 1Gb ram to upgrade from original 512mb. When I put both 1Gb ram in the slots, the computer will not boot up. When I take one out and put the original 512 back in with the other...
I don't know your specific model, but some of the Emachines had some memory directly on the motherboard. With the 1Gb and 512Mb sticks installed, boot the machine and report how much memory the system sees. Perhaps the onboard memory is causing you to exceed the 2Gb limit.
Please post the memory size you get here with the above sticks.
Thanks,
Dan
May 12, 2011 | E-Machines W6409 (7234) PC Desktop
Emachines sm controller driver for w6409 windows XP
go to the emachine website and locate the suppot tab. enter your computers serial number then operating systems and download and run the chipset drivers. this will resolve any sm bus controler issue
Jan 19, 2011 | E-Machines W6409 (7234) PC Desktop
My emachines w6409 restarts over over and over
There is either a virus or Malware that causes that problem. If you have a Win XP CD put it in and try do a system restore from the earliest possible time. Or do a system recovery; it re-formats your hard drive to like it was when new.
Aug 28, 2009 | Gateway Computers & Internet
Emachines W6409 that restarts over and over
Have you done any work inside the casing lately? Removing /installing or anything inside the casing?
If you have, check to make sure there are no wires touching the metal casing, or rubbing up against something inside the computer, that shouldn't be.
My brother recently had this problem. I hope this helps at least some. Good luck!
Jul 29, 2009 | Computers & Internet
W6409 eMachines Desktop Wireless Adapter issue.
Check out the emachines site. Just check the model number and all drivers will be on there.
Hope this helps
Mar 25, 2009 | E-Machines eMachines Desktop PC
Keyboard and now monitor work when they want to
Its not problem with key board.
your RAM has become weak to start normal windows
get your RAM replaced
pls rate me
thank you
Feb 14, 2009 | eMachines W4620 Keyboard
Washing machine - Need to replace motor cupling on the kenmore 90 series
you have to access the coupling by removing the housing of the machine,
you can tilt it a little bit to the back so that the motor is in your front.
remove the water pump clamps so that you can remove the pump.
unscrew the screws holding the clamps of the motor.( hold the motor tight, it is heavy)
remove the clamps, the motor will fell..
remove the motor and you can see that the coupling is attached to its shaft.
one coupling goes to the shaft of the motor, the other coupling goes to gear box shafting, and the rubber ring is in between the two coupling.
normally, only one coupling is damaged and you can just replace that coupling. you have the other two parts as spare.
i hope this would solve your problem.
tnx 4using fixya,
drcool
Sep 11, 2008 | Kenmore 23822 Top Load Washer
Computers & Internet Logo
354 people viewed this question
David Payne
David Payne
