Question about GE Dryers
Dryer will not stay on
Problem with GE electric dryer Model # DBXR463EB0WW
When you trun the start button the dryer starts but then shuts down when you let the switch return to it's at rest position. I have replaced the switch but the problem continues. Anybody out there know of this problem and hoe I can correct it.
Thanks,
Jim
    Scholar:
  • 97 Answers
Http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100688
I would believe that you would be looking at diagram location 630 a.k.a. the motor. Many people don't know it but there start switch on the panel has only one function and that is to energize the start switch on the motor.
The only drawback to this is often times manufacturers will not, for some reason or another, sell you the switch but sell you the whole motor instead.
A problem like this could either be in that start switch in the panel making poor contact, or the start switch mounted on the motor (Recently, I was actually able to take one off where it mounts on thedryer motor and open it up in halves and file burned points inside), orwith the centrifugal device in the motor itself. (As cheap and simpleas these plastic start switches on the motor appear, due to perhapsliability or something, often you can not buy that start switch andhave to buy the entire motor with it on it.)
Or your problem may conceivably have a root cause where the dryer drumis in somewhat of a bind due to a drag on it caused by something likegummed up rear roller bearings (not all dryers have these rollers, butsome do), or idler pulley bearing (that is what puts tension on thebelt ). You'd have to open up a dryer access panel (some dryers haveone small panel in rear to get at hooking up the belt, some have alower front panel that pops off), carefully stare at how the belt isfacing and wound around your shaft and idler pulley, or take a pictureor draw a picture, and then after you pull the idler pulley closer tothe motor shaft and slip off the belt, then try to freewheel spin themotor shaft, the idler pulley, and the drum, and see how it feels toyou. If anything feels like it's binding that's probably your culprit.
Posted on Jul 29, 2009
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
Maytag performance dryer model PYE2300AYW won't stay running after releasing the start button
Maytag Dryer Won't Start - Testing the Start Button - YouTube
? 1:26
https://www.youtube.com/watch?v=gJwYV8HkTbk
Oct 7, 2013 - Uploaded by Bill Newberry
This video shows you how to test the start button on a MaytagDryer. ... dryer medc200xw0 will not keep running after releasing the start button.
GE Dryer won't stay on after turnin
Dryer won't continue running when start button released ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Jul 25, 2014 - 3 posts - ‎2 authors
When I push and hold the start button the dryer motor starts and heats. It will not continue to run when I release the button. All thermostats ... button released. Model Number: PYET344AYW Brand: Maytag Age: 5 - 10 years .... Check for 120vac on the purple wire at motor after releasing start button. If it goes ... GE Dryer will not stay running when start button released ...
Jul 26, 2014
Starts but won't stay running
Sep 12, 2013
Dryer won't stay running
Apr 23, 2011
Jan 11, 2011
More results from forum.appliancepartspros.com
Jan 01, 2016 | Maytag Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
I HAVE A GENERAL ELECTRIC CLOTHES DRYER. MY STARTER KNOB WILL NOT STAY ON. WE HAVE CHANGED THE SW ROTAR START BUTTON BIT STILL WILL NOT STAY ON. WHAT ELSE COULD BE THE PROBLEM? IS THERE A REPAIR MANUEL FOR...
When you open the door there is a "kill" switch that shuts off the dryer. It could be stuck physically or electrically. If the motor comes on at all then the motor is not the problem. If you have replaced the control knobs then this "kill" switch would be very high on my list of suspects.
Nov 28, 2009 | GE DBXR463EBWW Electric Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
GE clothes dryer,model DPXR483EA1WW
Well this morning I got up and pressed the start button on my dryer and it's been working eversince. Thank-you I will contact you if I have any more problems. Jessica
Jul 18, 2008 | GE DBSR453EBWW Electric Dryer
Dryer model NO.LGC8858EQO
check door switch and wiring to switch. It also has a thermal switch on top of heating element, should show resistence.
Jan 04, 2008 | Dryers
Dryers Logo
142 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
