Question about GE Profile PSI23NCR Side by Side Refrigerator
Unknown fault code flashing in my now defrosting fridge
Inside my fridge, (PSI23NCRBV) the digital control/display is dark except for "HRS" flashing in the display nearest the "turbo Cool" button. Fridge does not seem to be cooling, and sounds as if a circ. fan is trying to start, but can't get up to speed
  • GE Master
  • 4,654 Answers
OK we have either a main control board pe a temperature control board defective. Will need some one to unplug the refrigerator and on back examine the control board on both sides. Look for burn marks or signs of heat.
Like in this photo.
Here is a photo of the temperature control board.
If you have any questions I sponsor Repair Clinic and feel free to email me or visit my website.
SITE=> http://appliancepartsse.blogspot.com/
Email=> appliancepartsse@yahoo.com
Thanks, Sea Breeze
Posted on Jul 29, 2009
  • John Tripp
    John Tripp Jul 29, 2009
    Thanks for the rate! There are different possibilities on your refrigerator problem. But for sure it's something in on of the boards. But like I said sometimes you can see the problem and sometimes it's hiding in part of the board. Let me know if you need more help. I'll be happy to help you. Sea Breeze
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Why has my fridge stopped working but my freezer still works its Hotpoint mistral plus
Possible that there is block on the air passage from the freezer fan which can be due to frost or failure of the fan.You need to check if there is free flow from the fan, also the setting of the fridge temperature.
Nov 26, 2011 | Refrigerators
Hi. I own an older Samsung SR-S2028CSS fridge/freezer. The temperature control setting and ice mode selection buttons were ineffective and the fridge and freezer had increased in temperature, but...
blank display with segment flashing is a fault code samsung appliances use this method for displaying faults ...
samsung fridge freezer trouble shooting videos are available on youtube ..
have alook at this video and see if its the same segment that you have
Jan 20, 2011 | Samsung RS2534 Side by Side Refrigerator
Hi,,,Igot this 2005 crown vic ,,and has a airbag lite on displays ,code 2293,,and blinks 68..6....8... What could it be?
Lamp Fault Code (LFC)
When the Restraints Control Module (RCM) detects a system fault, it will flash a coded sequence which is called a Lamp Fault Code (LFC) on the air bag warning indicator located in the Instrument Cluster (IC) module. The code is 2 digits. The first digit is flashed with a 0.5-second interval between pulses. There is a 2-second pause before the second digit is flashed, which also has a 0.5-second interval between pulses. There is a 5-second pause between each display of an LFC.
Each LFC is flashed 3 times after which the air bag indictor will remain lit for the remainder of the key-on cycle (except for DTC B2792 [cross link between firing loops] which only flashes one LFC). If there are multiple LFCs, each LFC will flash in order of priority.
--------------- Supplemental Restraint System (SRS) Lamp Fault Code (LFC) Chart LFC 6-8 31 Restraint System - Impact Sensor Fault (Passenger Side Short to Ground Fault) GO to Pinpoint Test M.
Nov 17, 2010 | 2008 Ford Crown Victoria
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
HRS flashing, nothing getting cold
Your refrigerator has a control board on the back behind a metal panel. Unplug and look at both sides to see if you see burn marks or loose solder. Go to this site and place model PS123NCRBV into the model search feature.That will take you to 13 similar models. The board on back is my first concern and the control inside will need to be looked at also if you find no problems on the back. The control board number is WR55X10656 let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE Profile PSI23NCR Side by Side...
GE side by side fridge not cooling, can't adjust temp control
Most likely it's not defrosting, many GE fridges need new defrost heaters every couple of years.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana Fridge defrost problem
the board needs to be programmed to the fridge. directions should have come with the part. if not i might be able to find you a copy
Oct 30, 2007 | Amana ABB2227DE Bottom Freezer...
GE Profile PSI23NCR Side by Side Refrigerator Logo
383 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
