SOURCE: dishwashing liquid was placed in the jetdry compartment
hi thanks for the question no its not ruined . just keep filling using vinegar , that will cut down the suds .do it 3 or 4 times problem will go away thanks the appliance doc
SOURCE: Dishwashing detergent in rinse aid compartment
not good there is no way to drain it out. you might be able to take the door apart and take off the rinse aid reservoir and clean it out
SOURCE: which comaprtment for the washing liquid ?
Compartment 1 is for Pre Wash
Compartment 2 is for Main Wash
Compartment marked with what looks like a star is for conditioner.
Bosch manuals can be downloaded from www.bosch-home.co.uk
SOURCE: In which of the 3 compartments should I put a liquid soap?
The small centre rack is used for whitening agent! The extreme right for the pre wash.
For delicates you have to use the same rack and finish the load. See to it there are no remains of powder, if your load is delicate material.
SOURCE: Liquid detergent compartment is filling
Hello
This what I do to solve this problem, it is most often caused by detergent build up blocking the passages and causing slow draining.
Solution:
Boil 2 quarts of water, slowly pour it down into the compartment (be careful) this will dissolve the deposits and clear the drain, repeat if needed, it really works.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
