Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
Craftsman air compressor spitting sparks behind fan
Severity increases til smoke is produced. Then I it shut down. Builds pressure. and sounds fine.
If it is an oil type make sure it has oil. If it is the dry type you need a new compressor.
Posted on Aug 01, 2009
Craftsman 1 1/2 hp air compressor model 106.152680 builds air but when it shut off it feels like air leaking out of pressure switch someplace.
It will leak until head pressure is drained. I'd it keeps bleeding until late no more air in than your tank check is bad
Apr 02, 2017 | Craftsman Air Tools & Compressors
Pressure won't re-build after cut-in
So you are saying that it starts and builds pressure and then shuts off, then when it comes back on again, there is no pressure? Sounds like the unloader valve is sticking open.
Aug 08, 2013 | Craftsman 3 gal. Air Compressor, 1 hp,...
My a/c is inoperative, clutch will not engage in normal operation. i am t getting two codes p1540 refrigerant overpressure/ac compressor disabled and u1000 class 2 communication malfunction. i have...
The wire that you found hanging probably goes to the a/c pressure sensor. Basically, this sensor will shut the compressor down if your system builds up excessive pressure. This would not affect the fans just the compressor. I hope this helps you figure this out.
Aug 16, 2010 | 2002 Cadillac Deville
Craftsman 3 gal., 1.5 hp air compressor: won't auto shut off, builds only 40 lbs pressure, air leaks from the 2 holes in oil filler cap?
The compressor will not auto shut off until it reaches the preset pressure which is usually around 100-130 psi - your problem is leakage of air from the oil filler cap suggesting that you have a failed internal valve.
Sep 24, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Rpm drops while adling causing 'grinding' sound while white smoke flows from behind or below radiator.
You should replace the cooling fan. With the ac on and no cooling fan, high pressure builds in the condensor and compressor bogging the engine down. When it gets too high a relief valve dumps and you get what appears to be white smoke. It's actually freon, hence the smell. I've replaced several PT cooling fans with the same symptoms.
May 16, 2009 | 2007 Chrysler PT Cruiser Touring Hatchback
Builds pressure, will not cycle back on and leaks fluid
Your compressor is most likely made by Campbell Hausfeld. The oily substance could be leaking from the capacitor on the motor. Remove the cover and examine the capacitor for failure. There is a value printed on the cap. (uf) The cap must measure to within 95% of printed value. A failing capacitor will cause the hum that you are experiencing.
Dec 27, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Automatic shut off craftsman 1.5 hp compressor
It sounds like the pressure switch is defective or the unit is miss-wired . If you have the owners manual check for a wiring diagram and follow the chart to try and locate the problem. If it is new return it to the place of purchase and have them fix or replace it.
Sep 03, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
207 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
