SOURCE: LG PHONE PICTURES INTO COMPUTER
you need to go to your menu bar
go over to settings and tools
go down to memory click on phone memory
down to my pictures
click options
move
mark all
and click done
and they should all move to your memory card.
hope it helps!!
((same for Videos))
SOURCE: I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be
sent to another phone, including a mobile phone. Once activated, all
your calls will be sent to the forwarding number you request. Each time
a call is forwarded, you will hear one short reminder tone on your home
phone, but you will not be able to answer the call from your home
number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
SOURCE: Unsupported message type
hi. it might be some virus kind of thing tarnsfered to ur mobile from other. it may even comes as text messages. rate me
SOURCE: deleteing txt messages on a LG enV2
try this
Using the Internal Keypad
1. Open the flip and press[MENU].
2. Press Messaging.
3. Press the Right Soft Key
[Options].
l Press Erase Inbox to erase
All (read and unread) Messages
or Only read Messages in the
Inbox.
l Press Erase Sent to erase
all unlocked messages stored
in the Sent folder.
l Press Erase Drafts to
erase all unlocked messages
stored in the Drafts folder.
l Press Erase All to erase
all messages from the Inbox,
Sent, and Drafts folders (except
locked messages). You can
choose whether or not unread
messages will be erased.
4. Select Yes to erase the messages
selected.
A confirmation message is
displayed.
SOURCE: I cannot delete photos from my n97, there are 127
Use the Nokia Photos application on your PC. Connect your phone to the PC using for example USB cable. In the left top corner of the application the name of your phone should appear. Click on it - it will turn green. Now you will see the photos on your phone. Select the icons that you want to delete and press delete (on the keyboard).
