Question about Yamaha RX-V663 Receiver
My receiver shuts down frequently , wakes back after 2 or 3 sec .
This kind of shutting down happens ater usage of 4 hrs. once this symptom starts. it frequently shuts down with a click sound and wakes back after 3 secs. i have noticed the vedio quality in TV seems like waves going down. with back shades. i tried switching off the receiver and plugging off all speakers attached. then also it responds the same way. pls helpme. what could be the reason behind this.
kesavan k7here@gmail.com
Do you have sufficient space around the unit? If it is in an enclosed space, has other components on top, etc, you may be overheating the receiver. Once it gets too hot it can potentially cause the issues you mention above.
If you have other components on top, try moving them to another shelf or below the receiver, and if you have a door on an entertainment center, leave the door open to help with air flow.
Posted on Sep 16, 2009
Amana electric dryer NED5100TQ0 SHUTS OFF ATER 5-10 MINTES.
check the vent system,most common cause of motor over heat-shut down.if motor makes a loud noise at start up, motor is likey bad.
Mar 15, 2014 | Dryers
System runs from about 3 to 15 secs then shuts down. That doesn't give me enough time to do anything in the BIOS setup when pressing F2. Then the system refuses to start (by pressing the power button)...
Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged. The computer should stay on even without an operating system or hard drive installed.
Jun 24, 2011 | Dell Precision Workstation T5400 Quad Core...
"Stability Control Fail" light on.
first job is to check the part load and main beather hoses are ok the stability system light may be a false indicator if the engine has stalled best is to get fault codes out of the ecm with a code reader to help but air leaks on the engine inlet side can cause strange/seeming unrelated symptoms
Aug 22, 2017 | 1997 Jaguar XK8
My comp shuts down at least once a day. i shut it off wait a few sec and start it back up, seems to be good for several hrs. i have run ccleaner and microsoft essentials and they both allways say there is...
it could be a power supply issue.. shut down the computer
remove all connections that go to the power supply , look inside the connectors and inside the mainboard coinnections, make sure there is no corrosion or dust in the connections
use something , like CO2 air can to blow off the dust from the mainboard..
plug all connections back.,. start computer ..if problem persist, it couls be a hardware or s/w compatability issue.
Nov 01, 2010 | Computers & Internet
NAD T747 Shutting Down
get a fan or do a re-stack...open the back of the e-center, Yes it will do a thermal shutdown... just like 3 mile island
Dec 10, 2009 | Audio Players & Recorders
Gateway W340UA laptop - no display...
Sometimes it di happen , specialy in most laptop which is being used more frequently and longer usage, the advisable use of a laptop is atleast 2 to 4 hours then shut it off and have cool down for 30 minutes to one hour then you can used it again, unless you got a support inclined base for laptop with support ventilating fan to help down minimize the heat accumulated during the usage.
have it check your video card with the proper technician, but first try to cool down your unit and try to open it again, and if still does'nt work then have it check by the service center
Nov 03, 2009 | Gateway Computers & Internet
Iphone hangs during standby mode.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Sep 26, 2009 | Apple iPhone Smartphone
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
When I put the computer to "sleep" it decides to come back on by itself. This happens frequently, but not all the time. What could be causing it to do this? Also, if I shut the computer down,...
Sleep on Vista is a combination of Standby and Hibernate. First it will go into Standby and then later if a laptop it will go into Hibernate. Any movement of mouse or keyboard may cause it to wake up.
Some computers will wake on Lan. If you have ethernet connected this may be the cause. You can turn this off by using Device Manager - Hardware - Select ethernet adapter - driver - Advanced - look for Wake on Lan and Pattern Matching and disable this.
ALso check your BIOS settings and disable all Wake on XXX settings.
Nov 15, 2008 | HP Computers & Internet
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Yamaha RX-V663 Receiver Logo
99 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
