Question about Philips Televison & Video
Model number 729/728. All operations work OK but DVD only plays in black and white. It is set to PAL.
SOURCE: DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Posted on Jan 08, 2008
SOURCE: Picture only shows in black & white when playing DVD
I had the same issue. Just disconneted the S-VEDIO and now using the vedio connected and color start showing again
Posted on Apr 30, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Posted on Nov 29, 2008
SOURCE: my curtis dvd player model
Curtis = JUNK. Our Curtis DVD failed after only 3 weeks (Horizonal Hold). The remote was **** from day 1. Replaced it with a Sony DVP-NS700H/B with Multi Disc Resume - WOW - a GREAT feature/ player! Cheapo JUNK is ALWAYS a poor value. Stores that sell **** like Curtis - likely sell other "poor value" JUNK as well - we'll avoid um' like the plague ... Consider it a lesson learned.
Posted on Dec 17, 2008
  • 537 Answers
SOURCE: how can i change sattings NTSCto PAL in my Philips DVP620VR DVD
Check this link to find the manual for your DVD player:
http://www.retrevo.com/support/Philips-DVP620VR-DVD-Players-manual/id/446ag723/t/2/
Posted on May 06, 2009
Why does it only play dvds in black and white
check color system settings pal to pal
TV PAL then DVD player has to be PAL
TV NTSC then DVD player needs to be NTSC
If mismatch in settings you may experience black and white
Dec 31, 2014 | JVC TH-A30 System
Black and white
Yes your player has gone into a wrong region make sure that if your tv is pal it must be pal NTSC will also make it go black and white check tv input and DVD player settings
May 04, 2014 | Digihome LCD TV
My lg dvd player doesn't show images (except the black and white diplay on the screen) but i can hear the sound playing, the kids might have changed some thing in the setup. please help if there a
Hello
You haven't given the exact model number ot your LG DVD, so I can only give you a general solution to this problem.
Get into its meny, surf through, come to SYSTEM adjust window, change the system. If a NTSC system recorded disc played with PAL system adjustment with DVD, there will be only black/white pciture, and vice versa.
Adjust it to the color system thathave been adopted your country. this must solve the problem. OK.
Jan 31, 2012 | LG Televison & Video
We have a Philips Magnavox Model #TP3284C101 TV and plugged in a Durabrand DVD Model #DVD1002 player to it. It will only play in black and white on this TV. But when we plug the DVD player into another TV...
It sounds like you have a standard problem.
Is the TV you are using, that gives the black and white picture, the same as the other ie, both NTSC or PAL and both on RGB or Y-C or S-Video?
Check to see what is required and set the DVD player accordingly.
Hope that helps.
Dec 10, 2010 | Philips Magnavox 27MS343S 27" TV
Black and White Image
Yes there is video format for our TV and dvd players. NTSC & PAL...
NTSC SYSTEM SELECTED IN TV & DVD PLAYER PLAY PERFECT NTSC CDS & DVDS, BUT IF PAL CD OR DVD IS INSERTED SUCH PROBLEM COMES.
EVEN IF, THE DVD PLAYER SETTING IS KEPT AS PAL, AND WE INSERTING THE CORRECT CD OR DVD AND ALSO IT SHOW BLACK & WHITE PICTURE, ETC.... so please check your video system in TV, DVD PLAYER and check the CD or DVD you are inserting is of same video format you have set in DVD player.
Apr 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Certain dvds only play in black and white
is yor dvd play pluged into the tv or is it pluged into a vcr if it is plug it right into the tv.
and are you watching a black and white movie
May 03, 2008 | Televison & Video
DVD player will only play in black and white
are you using a/v inputs or composite inputs .
Mar 27, 2008 | Disney Princess TV/DVD Combo
TV plays color, dvd black and white
If I understand your post/description, the DVD plays OK except it is in Black & White. If so, change setting from PAL to NTSC or vice versa depending on the region you are in. US operates on NTSC, Most of Europe is PAL.
Hope that this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 19, 2008 | Jwin Electronics JD-VD138 DVD Player
DVD picture is black and white
Sounds like you are either trying to play an NTSC (US or Asian) DVD on a PAL (European) TV.
Go into the DVD settings and look for picture, video or display options.
If the DVD is set to NTSC, then set to PAL.
Jan 06, 2008 | Philips DVD 622 DVD Player
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Televison & Video Logo
43 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
