Question about Gateway MX6920 Notebook
Laptop willnot power up. I have checked the ac
Laptop willnot power up. I have checked the ac power adaptor. What else could be wrong?
  • Gateway Master
  • 4,806 Answers
It could be the battery which is at fault, take the battery out and try to boot it on AC power only.
Please post back with the results.
Good luck.
Posted on Jul 29, 2009
  • 11,896 Answers
The adapter could be faulty or your battery pack may be completely dead, last solution would be to change the power supply
Several keyboards with same prob. Willnot power up.Adaptor ok.Any suggestions or other issues to look for cassio 691 and 611
Power input sockets come away from the pcboard. Is the polarity of the power supply correct.
Nov 25, 2016 | Computers & Internet
My toshiba Satelite A200 is hang when AC adaptor is insert
Inserting AC adaptor while computer is working on battery power, may indicate that an arcing occurred and cpu got wrong data to stop sequential operation. You may have to turn on AC adaptor, after it has been inserted into your laptop while using battery power.
Feb 08, 2012 | Computers & Internet
My Lenovo s10 power adaptor (Input 1.7A, Output 20V 2A) was working just now together with the battery. After i didn't used the laptop for an hour and returned to switch it on, the power adaptor isn't...
hi,
You said laptop is working fine if just using the battery,that means that there is nothing wrong with the battery itself. Can yu please try to connect the laptop directly to the power outlet without using the battery just for the mean time,remove the battery and connect the AC adapter directly to the power outlet then power on the laptop,if nothing happens,that means that there is something wrong with the AC adapter itself or the power port on the laptop.
Hope this will help...
Jan 09, 2011 | Lenovo IdealPad S10 Laptop AC Power...
When i push the power butten, the indicator light flickers, then nothinghappens
Firstly remove the battery and disconnect the A.C adaptor. Press and hold the power button for 30sec and then reconnect them back and check.
Check the port where u connect the A.C adaptor pin if the light is glowing then need to reseat the RAM and the Hard drive of the laptop (Compartments located at the bottom of the laptop)
If still not comming on then Hardware issue take it to local store.
But if the port where u connect the A.C adaptor doesnt have light then
1. check with different wall outlet
2. check if the adaptor is getting warm or not if not then replace it.
3. If yes then better check with different ac adaptor
Mar 31, 2010 | Acer Aspire 5100 Notebook
I have a HP dv7 laptop it does not work with the ac adapter but worked with the battery, whenever it is working with the battery and the ac adapter is connected it shuts down.
Remove the battery and plug the ac adaptor in check wethere the light on the port where you connect the ac adaptor glows or not, if no then check the wethere the ac adaptor is getting warm or not after you plug it in for few minutes if not then ac adaptor has to be replaced.
If the light on the port is glowing then it is likely that the power supply of the notebook has gone bad as it is not able to switch to ac adaptor or the port where you connect the ac adaptor to the notebook has a short circut when the acadaptor pin is connected , better try with a different ac adaptor to be sure wethere the issue is with ac adaptor or the notebook.
My best wishes
Mar 19, 2010 | HP Pavilion dv7-1130us laptop
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Toshiba Satellite M45-S331 willnot operate on
You have replaced the battery and then it worked.
Try once with power draining (remove the battery and then press the power button for one minute and then again refix the battery) and check.
Thanks
Dec 10, 2009 | Toshiba Satellite M45X-S331 Notebook
Post Boot message for my Dell Inspiron 1521 laptop. Message: The AC power adapter wattage and type cannot be determind. Please connect a Dell 65W AC adapter or greater for best system performance. To...
When you received the system as out of the box and you get this message "The AC power adapter wattage and type cannot be determind" let the Dell tech service know that they sent you a wrong or incorrect type of AC Adapter.
If this message not was not appearing before it just happened recently try to download and install the latest BIOS version from the support site.
If all fails remove the batt and check if laptop can work with AC adapter alone, because issues like AC not determine may not charge the battery and laptop may not work with AC as well, maybe laptop is already running on battery power.
Nov 11, 2009 | Dell Inspiron 1521 Laptop
Hp zd8000 wont turn on...
hi thanks for using fixya!!
Try first to remove the battery and connect the AC adapter to your laptop, you will use the power supply directly from the AC adapter without the battery. Turn on your laptop, then if its working normally as it should be,
Then try now to install back the battery then connect the AC adapter, turn it on. If still does not work, perhaps you have a problem with the battery.
If you need further assistance, let me know.
May 24, 2009 | HP Pavilion zd8000 Notebook
I have a Dell D600 (PP05L), its not powering up no lights. I noticed on the power adapter the green light goes out when plugged into ac power. What could be wrong here? please help
Hook up your power adaptor to ac power without it being hooked up to the laptop and see if the green light stays on. If it does then you know your adaptor is okay. if your adaptor is only hooked up to ac power and the green light still turns off then you know your ac adaptor is bad.
Take out the battery from your laptop. Now hook up the ac adaptor to the laptop and if it stays green then you know your battery is bad but you also want to make sure you can get your laptop to turn on. Hopefully it will turn on with only the ac adaptor hooked up to it.
May 04, 2009 | Dell Latitude D600 Notebook
Gateway MX6920 Notebook Logo
227 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
