Havent used my computer for awhile and i forgot the password i used
SOURCE: acer aspire 3100 series
If you where the CMOS battery is, there's beside it a jumper inserted in two of the 3 pins(left pin and middle pin). Remove the jumper from its original position and with it short the middle pin and right pin. This resets the CMOS ROM to its default settings minus the password. Return the jumper to its original position as before. Reboot the computer.
SOURCE: Password recovery for Acer Aspire 5315-2077
if she's not the administrator, then you could try resetting the password through the administrator.
to do this, all you ned to do is reboot in safe mode, and log in as the administrator. then jsut delete and reset the password as desired.
SOURCE: acer aspire 2920 forgot my acer security password
Steps for Clearing BIOS Password Check
If users set BIOS Password ( Supervisor Password and/or User Password ) for a security reason, BIOS will
ask the password during systems POST or when systems enter to BIOS Setup menu. However, once it is
necessary to bypass the password check, users need to short the HW Gap to clear the password by the
following steps:
q Power Off a system, and remove HDD, AC and Battery from the machine.
q Open the back cover of the machine, and find out the HW Gap on M/B as picture.
q Use an electric conductivity tool to short the two points of the HW Gap.
q Plug in AC, keep the short condition on the HW Gap, and press Power Button to power on the
system till BIOS POST finish. Then remove the tool from the HW Gap.
q Restart system. Press F2 key to enter BIOS Setup menu.
q If there is no Password request, BIOS Password is cleared. Otherwise, please follow the steps and
try again.
NOTE: The steps are only for clearing BIOS Password ( Supervisor Password and User Password ).
Below is the picture of the Jumper location by the memory modules. These two points have to be "shorted".
SOURCE: i cant get onmy computer
I'm assuming that you're using Windows OS? If so, here are the steps to reset your password:
Hope you'll get it resolved soon ;-)
