Question about Dell Computers & Internet
Having problem connecting to internet. says everything is working properly. but the wireless switch is not connected.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi, Before i advice you on what to do, can you tell me if the wireless is switched on and can see your network?
    Scholar:
  • 177 Answers
Sometimes ,when you try to connect to a wireless network ,you have to give windows the "SSID"of the network. usually Windows will detect it automatically, but not always. you need to go to Control Panel, then find the place in control panel where you see the word network or networking, then click on "Set up a network connection"
Posted on Jul 29, 2009
Wireless Connectivity problem
You can check the wireless adapter is working properly in device manager: control panel>hardware and sound, under devices and printers, choose 'device manager'. Expand the network adapters menu and find the wifi adapter. Right click on this and click properties. You can see if the device is working properly under the general tab. You can also try updating the driver; from the drivers tab, choose update driver and then choose to search automatically for updated software.
Also, try clearing browsing history and cookies: Go to start>control panel>network and internet, under the internet options heading, choose 'delete browsing history and cookies' restart the browser.
Apr 03, 2012 | Dell Inspiron Computers & Internet
My Rangemax wireless wndr3000 is not working properly, though it has in the past. The problem seems to be that I'm hooked up to the wireless network (ex. I can print wirelessly), but with no internet....
Same situation here. Wired connection from modem works fine. I can also log in to the router via routerlogin.net. However, the router does not detect an internet connection.
Jul 12, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
After connecting router wbr-1310, DSL connection states "limited to no connectivity." What could be causing that problem and how can it be corrected to operate the router?
limited to no connectivity with a wireless system means that it is not picking up the signals from the internet device you have, check if everything is plugged in properly and that your internet connection (modem) has enough strength to be able to be wireless.
Sep 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Connected to acess point but internet
The first thing you should try is connecting one machine via a cable to the router, to see if the connection is stable. This will prove the router is working, or not, as the case may be. Assuming the router still fails to function properly, you can then replace it.
However this assumes that the modem and internet connection are working properly. If either is causing the problems, then the router might be just fine.
But if the router does appear to work fine when wired in, then it at least proves everything outside the router is fine. And while it is possible, it is rather unlikely that just the wireless part of the router failed without killing the switch/router part.
So try this, and once we have the result, we can take the next step
Jan 29, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Jan 23, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
The other computer wont log on to the internet
hi, even if it's connected properly if its not properly configured it still wont connect..so does it mean that other pc could connect? how bout your main pc does it work? which pc wont work? whats the o.s.? if you like i could help you i just need to know the full detail so i could help you diagnose it
Nov 28, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
79 people viewed this question
Alun Cox
