Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Suspected broken fan prevents top fridge section cooling down
I have the same issue. I recently moved into a new house with a Bosch KGN33v00GB fridge/freezer which was left unused by the previous tenants for over a year. On plugging it in and switching it on the freezer section worked fine, but the fridge section at the top never cooled down.
Eventually after searching the internet for other people with the same problem I have come to the conclusion that the cooling fan which blows cold air up from the freezer to the fridge section has broken. I've successfully removed it, but there doesn't seem to be any simple way of testing it. It doesn't seem to have siezed up, but I don't think it has been working for a while. Ordering a new one for £70 from bosch seems a rip off, but I think it's the only way to get this badly designed fridge/freezer to ever work properly!
    Champion:
  • 363 Answers
Very good diagnosis and conclusion. That price for the motor is about right. I think you will not have any truble with the ciculation after you install the motor.
Posted on Jul 29, 2009
Fridge section is warm freezer is cold fan not working can hear the motor from thr fan but fan is definately not spinning. BCH KGN33V00GB
Hello Tonytonz953,
I understand that you are needing to change the fan on your refridgerator. The fan is loacted in the freezer section and has an outlet that blows in to the fridge compartment. You can order the fan at the following link http://www.ransomspares.co.uk/parts/search/fan-/bosch/fridges-freezers/kgn33v00gb%2f06/b/c/m/ this is the cheapest on that I could find and the cost is 75.85 pounds.
Thank you for choosing FixYa.com
Justin
May 11, 2011 | Microwave Ovens
My Bosch kgn33v00gb fridge/freezer is up the spout. The fridge is not cold at all, but freezer is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 08, 2011 | Bosch Refrigerators
There is a buildup of ice behind the lower section of the plastic back panel which eventually prevents the door from closing.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Bosch Exxcel KGV35421 Bottom Freezer...
Bosch Fridge, Freezer OK but Fridge won't cool
Well nobody came up with any other options so I guess it's just defrost a "nonfrosting" fridge every three months or so, just like the old days.
No progress here then in spite of advances? in technology.
Oct 10, 2009 | Bosch Refrigerators
When doors are opened it stops. Ice is forming unnaturally in the
It sounds like you may have a bad evaporator fan motor or broken blade.
Another cause could be a failed defrost system component. The would cause a build up of ice and frost and the fan blade could be coming in contact with the frost or ice.
The fan stops running when the doors are opened on this model to prevent the circulation of warm air.
Sep 11, 2009 | Bosch Refrigerators
Fridge not cooling, freezer fine
You might try removing and ohming out the door switches before you remove the fan motor. for fan motor operation the switch should read open on the NO to C and closed on NC to C with the switch out of the fridge. push and hold in the switch and the opposite readings should be observed IE closed on NO - C and open on NC - C. look closely at the switch for these letters.
If you have an electronic control system with an led or lcd display a magnetic switch may be employed and this would do both operations with a magnet close to the switch acuator.
Jun 20, 2009 | Bosch Refrigerators
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
Bosch Classixx fridge / freezer
Hi - experienced this myself and spent ages trying to get to the bottom of it - only found one post but it worked and was absolutely clear on the cause nb: i'm not an "expert" !
My understanding of how the Bosch f/f works is that the freezer compartment generates the cold air for the fridge which is regulared at the fridge end . At the back of my fridge there are two "vents" which feed up this cold air up from the freezer into the fridge.
Problem happened to me because I left the freezer door slightly ajar which generated a massive amount of frost (sucking in the moist air from the house I guess then freezing it) and subsequent ice froze up the cooling ducts between the freezer and the fridge. Therefore, no matter how much I turned up the fridge thermo it never got cool. Only solution was to dump my frozen at a mates house and defrost the the FREEZER for a good 24 hrs +.
Worked tho' - fridge was completely back to normal.
PS: I understand this issue may also happen if you put too much unfrozen food into the freezer at one go and in working overtime to get it frozen causing a massive frost up again.
Nov 01, 2007 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
621 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
