Question about Kanguru 3.5 QS2 SATA Ext HD 750GB 750 GB USB 2.0 Hard Drive
How to setup 750 gb drive usb. two disks which one is first. no manual came with it
  • 416 Answers
Your question is bit confusing.. but if you have Winx Xp you need not setup anything. just plug in the USB cable & you will have the Drive showing in mycomputer
Posted on Jul 29, 2009
How to format a maxtor one touch III on aspire m3201 acer computer using vista
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your operating system
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Aug 01, 2012 | Seagate Maxtor One Touch III 750 GB USB 20...
My G DRIVE Mobile 750 GB only has 126 MB
Click the "Start" button, type "diskmgmt.msc" and look at the Disk list from 0~x and find "G Drive (E: )". Check the disk on the right side with a blue long bar on top which is partitioned disk. It will be one blue partition indicating that the HDD capacity is near 732GB. If the G Drive has more than one partition on it, then u need to delete all and merge it to one partition. Go to partition and just click right button of your mouse, choose "Volume Delete(D)" and proceed to delete. If all partitions are deleted then right click to make a new volume "New Simple Volume" and follow the wizard's steps to create and format(NTFS) your new volume. This will solve your problem and if not, it might have a HW error or any problem with the disk itself. You'll need to check it at the Apple store where you bought it.
BTY, PC NTFS formated HDD might need a utility for the MAC os to read the HDD properly. You can use NTFS-3G or Paragon NTFS, but "Mounty for NTFS" will be the easiest one for you.
Apr 30, 2017 | Computers & Internet
How cant to make password my 500 GB TRANSCEND HARD RRIVE
The best way to password protect hard drive is to encrypt it. TrueCrypt is very good encryption software.
Download TrueCrypr here
Tutorial: how to setup TrueCrypt
May 24, 2011 | Transcend 750 GB 2.5-Inch USB 2.0...
Just bought the GoFLex Pro 750 GB. I have two PCs, both on XP... neither can see the HD via my computer... I have done a check via computer managment and it says the HD is fine... but it is not...
Hi, Thanks for using fixya.
Try this go back in disk management right click on the disk assigned to your GoFLex Choose change drive letter and paths. After you make the change go back in My Computer and see if you can ues it.
Terry
Feb 17, 2011 | Seagate FreeAgent GoFlex Pro 750 GB USB 30...
My external hard disk is not being detected on my computer and i think there is a problem in the disk....the spin is not there inside the disk
Hello
These symptoms shows that the Hard Disk may gone damage, if it is in warranty period then avail it immediately.
Good Luck
Jan 01, 2011 | Seagate FreeAgent GoFlex 750 GB USB 20...
I have verbatim external drive usb 2.0. It used to function properly...but now Windows(xp) doesn't recognise this device. I have tried it on serveral pc's & same result.
An external drive has two major components -- the disk-drive and the USB-to-disk-drive adapter. Open the enclosure, and remove the disk-drive, and connect it as a 'slave' disk-drive in a desktop computer, to see if that interface hardware is the problem (and if the disk-drive by itself is 'readable').
May 07, 2009 | Verbatim External, USB 2.0, 750GB...
Cant format 400gb usb flash drive
So the disk is recognized? And there is a valid partition on the disk?
What is the error you are getting?
Have a look at this external hard disk troubleshooting, maybe it helps you along.
Jules
Apr 21, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
750 GB Hard Drive support on intel 845 motherboard
Hi prabhatkumar, your Intel motherboard's bios will see the drive. The question is will windows?
Do not use windows to setup the hard disk drive. Download the free bootable software for a floppy disk from the manufacture's web site. Boot the system to the floppy & format the drive. You'll be able to set the cluster size (Like windows would do) but the software from the manufacture is far better than windows. Any version of windows XP will see your total drive size. Just make sure the drive is seen while in the bios. (If it will be the primary drive make sure it is listed in the boot order).
Good day prabhatkumar!
Run into any issues just drop me a note.
Mike
Sep 23, 2008 | Intel D845HV (735858149143) Motherboard
Kanguru 3.5 QS2 SATA Ext HD 750GB 750 GB USB 2.0 Hard Drive Logo
60 people viewed this question
Top Kanguru Computers & Internet Experts
David Payne
David Payne
Are you a Kanguru Computer and Internet Expert? Answer questions, earn points and help others
