Question about Vizio VX37L Television
No signal...deep sleep
After thunderstorm tv went off. trying to turn it on and it goes to "no signal" and then to "deep sleep mode".
  • 11,896 Answers
Go to main menu, turn off sleep mode, then find the "autoprogram" feature and select it.
THis will program all available channels, just make sure you tv is set to AIR for regular tv and CATV if you have cable.
The thunderstorm may have reset the television. Hopefully there is no damage done to the tuner
Posted on Jul 29, 2009
Im using my tv as a monitor, when i turn on my music and then leave the computer to do chores, the computer goes to no signal and i cant listen to my music, how do i keep it from doing this?
Sounds like either your computer is in hibernation mode or your TV is set to sleep, what type of connection to your computer are you using? I do believe in this model Vizio there is a sleep option on each of the Video sources. But I would guess its your computer going into either sleep mode or in your running windows 7 Hybrid sleep mode.
Jul 02, 2011 | Vizio L32 32 in. LCD HDTV
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
Brother HL-2170W laser printer goes into sleep mode quickly. How can I turn off the sleep mode.
I found this from Tony Benjamin
I have tested it on two different Brother Lasers and it worked.
To cancel DEEP SLEEP on Brother Printer
  1. Go to General Setup then OK
  2. Ecology then OK
  3. SLEEP TIME then OK
  4. While sleep time is display push Down Arrow and CANCEL at the same time!
  5. DEEP SLEEP on/off toggle by Arrow keys
  6. OK to SAVE Deep Sleep off.
It is a shame they don't have this in the web interface or manual they sent with the printer.
Nov 03, 2010 | Brother HL-2170W Laser Printer
Deep sleep mode on digital tv
We turn off the TV. Turned it back on using the tv turner remote that comes with the set, we push the HDMI1 mode button immediately! Must do before it goes to Deep Sleep mode. You should not use RGB mode as this will cause the problem to repeat. (Vizo HD 50") Keep trying if doesn't work the first time. You have to be ready and quick to get the mode HDMI1.
Oct 28, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Why does my monitor say "no signal" when you try to us my computer after it has been on sleep mode?
The computer turns off the signal to the monitor after it goes into sleep mode. You can adjust the power settings in the computer to not turn off the monitor.
Sep 21, 2009 | Acer X193W LCD Monitor
Ipod in sleep mode
How to Enable Sleep Mode :
1. Access the main menu on your iPod
2. Go to the extras menu > clock
3. Select your current time ensuring that your timezone settings are correct
4. Select the Sleep Timer options
5. Select the time that you want your iPod to shut down
And if your iPod goes into Deep Sleep Mode then here is the answer to that :
Right "Deep Sleep" is a battery saving mode if the iPod is not touched in say a 18-24 hour period I think. It reboots (resets) coming out of this mode.
1) There are people reporting that they must always reset their iPod to turn it back on after shutting it off, they don't really mention deep sleep at all, search for "must always reset" or something along those lines
2) I'm not sure if this is documented anywhere specifically. It is a normal function of the iPod that we discovered somewhere along the line. Not sure where the first talk about it came from, you may find information on this searching "deep sleep" there was a hack to force the iPod immediately into deep sleep once upon a time.
3) Not exactly. If an iPod has gone into deep sleep, plugging it into the power will automatically start the reboot. In the case of buttons you should be able to touch a button and it will start to reboot, I have found with my 3G iPod it takes a very deliberate touch or two or three touches to the touch sensitive buttons to get it to wake up, but you shouldn't HAVE to do the reset command (i.e. menu/select button held down), if you do you may be looking at more of the original problemin #1
Sep 19, 2009 | Apple iPod touch
Plasma vizio 50 inch goes into deep sleep mode
when turned on tv no signal comes on a few minutes later deep sleep mode and tv turns on
Sep 17, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Sep 11, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio VX37L Television Logo
2,074 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
