Question about Whirlpool RBS275PD Electric Single Oven
After self cleaning the oven, now the oven won't heat up
After using the self cleaning feature on the oven, now the oven won't heat up
    Guru:
  • 310 Answers
Usually this is caused by either a bad temperature sensor, a shorted wiring harness, or commonly a faulty controller. The temperature sensor and wiring can be checked with an ohm meter.
When you program the oven for a high temperature what does the display read after ten minutes or so?
- www.fixyourboard.com
Posted on Jul 29, 2009
Need manual for self cleaning, please?
Hello Mary;
You can get a user manual at the following website.
Locate your oven model number. It is located on a label either on the face of the oven when you open the door or on the side of the door. Put he model number into the website and you will get diagrams, component part numbers and manuals.
http://www.searspastsdirect.com/
I suspect the user manual is not going to help you. Tell me the model number and what is going on.
Manufacturers offer the self cleaning feature on ovens because customers like this feature and the ovens sell. Yet, the manufacturers engineers have not been able to provide a design that will protect all of the components from self cleaning temperature of 900-1,000 degree F.
When you go into the self cleaning model, the door will lock when you reach 500-550 Degree F. The oven temperature will raise to 900-1,000 degrees F. The oven door will not open until the oven temperature drops to 500 degree F after the self cleaning cycle is completed.
Now, You have a high temperature limit switch in your oven. If this switch fails, you will loose power to your control board and you will not be able to open the oven door.
If you have never used your self cleaning feature, the high temperature limit switch may have failed.
Do to the problems involved with the self cleaning feature, knocking out the control board from heat, additional heating element failure, and other components; It is in my professional recommendation as well as my fellow technicians not to use the self cleaning feature. If you do, do not run it for more than 1 hour instead for the manual 4 hours.
Mar 14, 2016 | Ovens
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Do i have to take out the oven racks before I self clean the oven?
If you don't take them out the high heats can wreck the finish on them and turn them all kinds of crazy colors.... but if you don't care what they look like after the cleaning you can let them in...
My recommendation is to not use the self cleaning feature...
Self Cleaning Oven Problem
It is more like a self destruct feature.... it causes many problems with ovens and ranges from the high heat...
heatman101
Apr 21, 2011 | Frigidaire Ovens
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
After doing a self clean on a whirlpool oven model rbs245pd06 it will no longer heat on bake or broil.
Unfortunately you have found out the hard way about the self cleaning feature... they cause many problems...
Here is a tip that I wrote about that and it includes some things you can try to get you oven to unlock...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 30, 2010 | Ovens
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
307 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
