Question about Fisher Audio Players & Recorders
I HAVE ONE CHANNEL ONLY;[LEFT SIDE].BEFORE I FINDER 2 FUSES BLOW FROM IC AUDIO OUTPUT STK4191 II.I DID CHANGED OF FUSES AND STK4191 II,BUT ONLY HAVE IT ONE CHANNEL.THANKS FOR YOU HELP
  • 21 Answers
SOURCE: Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Posted on Sep 03, 2007
hawkwatcher
  • 67 Answers
SOURCE: Reduced audio output from right channel
Try lightly tapping on chassis to see if you can get audio to cut on or off with vibration if you can most likely cause is bad solder connections. This unit is well known for poor solder connections especially around poweramp driver IC's IC701, IC501. Also Electrolytic Capacitors in unit have fluid in them and heat Evaporates the fluid causing them to not operate properly over time . Caps that usually go bad are around parts that run hot like Power amp drivers
Just a couple likely suspects.
Try unplugging overnight to give unit a Good Reset also double check all setup settings.
If you need service manual I may be able to get you one
kstahl65@att.net
Posted on Jan 20, 2008
SOURCE: no audio output
Check the numbers of the parst attached on aluminum heat sinker.
Posted on Sep 13, 2008
dthomas1969
  • 4 Answers
SOURCE: Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Posted on Feb 07, 2009
Grubhead
  • 5190 Answers
SOURCE: Technics 1310 turntable has left channel (white
There are just two causes, one is the preamp, which can be easily checked by putting the right channel jack in the left terminal. If the sound is normal, then it's likely that the cartridge in the deck is bad, or some wire is loose. However if the sound is still poor then the magnetic cartridge preamp in the amp has a fault. These are normally a single IC, which will have failed. Find the preamp by tracing the wires from the imput socket to the PC board, which may be alone.
Posted on Mar 21, 2010
My GFA 555II amp blew the 2 left channel fuses while playing at normal loudness levels.
Fuses blow when there is a short circuit. All you need to do is replace the main output devices located on the heat sink. They are the ones that will have shorted most likely. Check your speakers and wiring for that channel. Any wire cross connecting will cause that kind of fault, likewise a faulty speaker.
Any engineer will be able to do this job, providing they can find the parts. But you can check them yourself by looking for the parts on the internet.
Mar 03, 2016 | Audio Players & Recorders
Fuses on board blow after a minute or so after power up
Most likely the wire for the speakers, if you have them wired for a specified ohm that the amp doesnt support will cause the issue, as well as bad ground, cross connecting wires. I would start by removing all wires and connections, ensure they are clean and speakers are wired properly.
Nov 19, 2007 | QSC MX1500A 2-Channel Amplifier
I only have left channel on speakers working have tested speakers ok, swapped pre amp boards still one channel, swapped output boards the same. What could it be? Barry
is there Sound stage output is stereo if stereo then one side is missing or broken link from ic to speaker, If mono output then use with one side 2 speaker parallel.
May 20, 2015 | Audio Players & Recorders
Blows fuse when turned on?
You either have a shorted output transistor on the left or right channel or the voltage regulator in the power supply is shorted. It will continue to blow fuses until the part is replaced.
Jan 25, 2011 | Harman Kardon AVR 100
When right channel is wired it shorts out the power supply. Aragon 8008 when powered up without input and output, no problem. When connected with speakers and line level feed in, the left channel works...
Fuses blow when there is an overload caused by a short circuit. If the speaker you connect up to the amp causes a short. There is either a shorted part in the speaker or the wires to it are touching at some point. Assuming you can sort out the speaker issue and connecting a good speaker with good wiring and it still causes a short and blows a fuse. Then it's likely the output device(s) in the right channel have developed a short themselves. Perhaps as a result of being connected to faulty wiring or speakers.
Jul 18, 2017 | Aragon 8008 MK II 2-Channel Amplifier
I need to know the size of external fuses for a american legacy amp 2000 watt 2 channel 1990
25 to 30 amp fuses will work great, anything lower could possibly blow a fuse when a good bass note hits even if there is nothing wrong with the amp. Hope this helps.
Jul 09, 2010 | Legacy - American II: 2 Channel 2000W...
GLI PRO preamplifier fuses burn
You shorted the main semicondutors and they have now got a short on them, so they are acting just like a piece of wire and drawing too much power so the fuses blow. You need to replace whatever is on the main heatsink. Did both channel wires make contact or just one? If only say the right did you might only need to replace the right side parts, unless it is an IC doing all the work!
Jan 20, 2010 | Audio Players & Recorders
Installation
If you've got a standard 4 speaker system (2 front, 2 rear), your best option is to connect both left speakers to the left channel amp output and both right speakers to the right channel amp output. The only thing you lose is the ability to fade the speakers front to back.
Mar 04, 2008 | Legacy - American II: 2 Channel 1200W...
Sep 02, 2007 | Kenwood VR-305
No power
Check the unit for any Fuses, Fusable Links etc, if they are OK proceede on to testing, I often troubleshoot these issues via a stereo head set, modify the leads so you can "Touch" them onto the Speakers Output Terminals, connect the "Shields" together, thats "Earth" and the other Two, are Left & Right... with a Sinal feed in & the Amp's volume turned to about 25% volume, connect up the Earth wires to the Chassis with a clip, under a srew etc, just make good contact... then touch the Left & right wires onto the output, ya should hear sound... if not most probably the Output device(s) may have gone faulty.
Aug 03, 2007 | Legacy Audio American Legacy II LA290 Car...
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
