SOURCE: turn auto answer off?
You probably have auto answer turned on in your phone. The headset does not have this feature. You must find it in your phone to turn off auto answer while headset in use.
ps- second user- You canot use the phone handset with bluetooth device on. At least none that i know of.
SOURCE: Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
SOURCE: Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
SOURCE: cant turn off automatic voice that answers phone calls
Go to Menu, Tools, Voice Control, Voice Guide, and turn Alerts to "Off"
Hope this helps ^_^
