Question about Whirlpool Washing Machines
Overflow from drain pipe when the washer drains; i've had a couple of washers and have not been able to correct the problem, the problem is not the washer, i just need some solution to correct the problem
    President:
  • 1,273 Answers
Try a drain auger in the washer drain pipe. It'll take some time, as you'll have to get it through a "P" trap in the wall. You'll know when you're doing some good when you feel some resistance, and then you pass on through it. Do this several times, and chase each cleaning with water. When you are sure that you have opened the drain up, and you won't be going back in with the auger, you can put in some drain cleaner to finish off the job. A small auger with a hand crank can be had for ~$10 at a hardware store. Drill mounted types go up from there.
Hope this was helpful. Best regards, --W/D-- Please feel free to rate this solution!
Posted on Jul 29, 2009
Washer empties faster than pipes allow causing overflow
More then likely you have a partial clogged drain also, New washer output is alot faster, Being a plumber its not getting enough air to let it drain properly. Check drain for clog and vent is wrking properly
Mar 01, 2010 | Washing Machines
Washer is leaking out of overflow tube
first
check the drainage pipe, the hose goes into and make sure its not clogged, once you know there are no obstructions reattach the drain hose. be sure it goes a couple of inches into the pipe but has a little space for air flow between hose and pipe. I this doesnt fix the problem the hose made need to be raised, it should enter the pipe several inches higher than the washer. Hope this helps
Nov 28, 2009 | General Electric WHDSR209DWW Top Load...
My washer drain pipe is overflowing on my floor
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
Jul 26, 2009 | Kenmore 500 6953 Dryer
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Drain pipe for washer overflows..how do I clear it out?
if the water is coming up from the drain it means your drain is restricted you either need a plumber or you have to run a plumbers snake down the drain to clean it outl.
May 30, 2009 | LG WM0001HTMA Front Load Washer
My washer drain pipe overflows when draining. i've tried smaller loads, cleaning drain pipe & vent, and raising the drain pipe. seems like the washer is draining the water too fast.
no you have a drain problem .... i would recommend calling a plumber the only thing it could be is drain problem there is no such thing as draining to fast.
Apr 30, 2009 | Washing Machines
Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Apr 20, 2008 | Washing Machines
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
