Question about NRS Kayak Bilge Pump with Float
How do change the bilge pump on a sea ray 240 sundeck?
How to resolve oily bilge water problem.
Could be fuel line leak or even exhaust fume condensation.
Mar 05, 2017 | Cars & Trucks
How Many Watts To Run 15 amps bilge pump
Usually the bilge pump would be a 12V pump. So roughly 175W.
Aug 24, 2014 | Fish
How to wire a 12 volt automatic bilge pump. In a boat.
Hopefully the float switch for the Bilge pump is under the engine not the pump motor. Having an electric motor under an engine is a fire or explosion hazard Find the float switch for the motor and follow the tubing back to the pump. A replacement pump should have instructions. Only the pump intake should be in an explosive environment.
Aug 24, 2014 | Boating
My bayliner 2455 1988 model leaks in the front of the boat.
Could be a broken bilge pump. You can find some answers on the boating forum.
http://forums.iboats.com/bayliner-boats-37/?boatid=29
If the bilge pump is bad, you can find some on iboats.com
http://www.iboats.com/Bilge-Pumps/dm/view_id.217442
Mar 18, 2013 | Boating
Jet boat SL2000 bilge pump location how to access it
the tray that houses the cleanout plugs needs to be removed and pry'd up. thr pump is straight down from there.
Sep 08, 2012 | Rule Mate Fully Automated Bilge Pumps...
What is gph at 6 foot. seasense auto 800 bilgr pump?
If you are using a 3/4 ID hose for the output (or larger) then it should put out close to 800GPH at 6 foot discharge height.
Aug 29, 2012 | Sea Sense Academy Sports SeaSense Auto 800...
Bilge pump switch keeps cutting out when turned on
Check for water leak around pump or wiring. Check ground.
Aug 06, 2012 | Jabsco 18660-0121 Marine Water Puppy...
My pump pumps out my bilge but if the bilge fills up again the pump wont restart
Sounds like it is no longer automatic, essentially you need to replace the unit.
Jan 12, 2011 | Rule 1800 110V SumpUtility Pump Fully...
Electrical problem with console items, nav lights etc
It sounds as though the ground has been lost either at the batteries or along the way from the battery. Check for a good ground at the grounding shunt by using a known live source.If that is good you can run through the process of elimination by checking from the ground shunt to the pigtails, make sure each one is clean and tight. The fuses are often found to be corroded within, if this is the case you might want to change them over to marine quality breakers. It's worth it in the long run.Also make sure your constant feed to the bilge pump is live, it doesn't make sense for those two units to be out, especially the bilge pump. Check the back of your main battery switch for any corrosion or loosness.
Sep 05, 2009 | RCA Boating
Wiring on bilge pump
There's an installation manual available online. Black is negative ground; either brown or brown/white will turn on the pump. The intent is for a three way switch, connecting brown/white directly to positive 12 VDC while brown would go through an automatic switch (e.g., a float switch).
Mar 27, 2009 | NRS Kayak Bilge Pump with Float
NRS Kayak Bilge Pump with Float Logo
314 people viewed this question
Top NRS Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a NRS Boating Expert? Answer questions, earn points and help others
