Acquiring ip address
My pc is connected to my wireless router and says the strength is excellent but sticks on 'aquiring network address' and wont let me connect to the internet
  • Hippa May 15, 2009
    Everything shows excellent and connected to the wireless. Ethernet works but can not use wireless. All shows that everything should be fine and that it should connect.
You may need to set a key on your router and PC (recommended for security anyway). Access your router with your internet browser (default is often - listed in your manual) and get the long default key. Put this key into your wireless card set up and reboot.
Posted on Nov 23, 2007
Cannot get wireless internet to work. Set up wireless connection. Icon shows connected, excellent strength. There is another computer icon next to it on the task bar however that shows a red X through it,...
find that ip of the router e.g or something like that
gott to the lan network connection of pc
got tcip option
in ther enter the ip addree ( anything but ther router address)
subnet mansk
defualut gateway the routers ip address
primary dns router router ip address
leave the secondary ip blank
Mar 05, 2011 | Computers & Internet
Says i am connected but when i open firefox it says that i have no network connection... the wireless icon also says it is acquiring ip address
if the message aquiring ip address comes in computer then it says that the wireless router is not giving an ip address to your computer.... check if any static ip address is assigned to your wireless connection...if so change to "obtain ip address automatically".... right click on wireless network name> goto properties > authentication tab> uncheck "enable IEE athentication"
now try to connect again,still not restart the computer once...... this will resolve the issue.... still if it is not connected then check for the security settings in the router... if your computer is XP/MAC, it may not recognize WPA security type.... change it to WEP type and try to connect again....
Apr 19, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
I have netgear sky router belkin wireless g usb adapter sinal strength is excellent but it wont connect keeps saying acquiring network adress what can i do it has worked in the past and oblige
go to the router setting by logging in as a administrator then check the wireless setup access, then add your WIRELESS DEVICE 12 digital MAC address then apply it and logout
Sep 29, 2008 | Belkin Computers & Internet
I get an excellent connection message ,then it tells me it's aquiring network address but it does not make connection
If your PC is running XP, download this little program, and then run it, you will have to reboot, but it sorts about 85% of DHCP assigned IP address issues in one step
Please don't forget to rate this sugestion
Aug 29, 2008 | Linksys Wireless-G WRT54G Router
Laptop can't aquire IP address
This sounds to be a compatibility issue with either the wireless software or wireless card. Check to see if there are any updated drivers for the wireless card at IBM's support site. If there aren't any or the card still doesn't work after the updated drivers are installed, then you might try a different/newer internal wireless card, or a universal external wireless card for use with your home system.
Jul 30, 2008 | IBM ThinkPad R51 Notebook
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
253 people viewed this question
David Payne
David Payne
