Question about Macally IceCam Personal Web Camera
How do I save the recordings from the Icecam so that I can play them back later? What is the right extension to use so that Quicktime will play it?
  • mikel_modem Jul 29, 2009
    Will the *.wav also work for video. I know that it works for sound.
    Also, with the icecam, I don't believe one has the choice of using any particular software when one attempts to record sight and sound. It just does it, while asking you how you want to name the file.
    Earlier research said that it worked with the *.cif format. But, even when I saved the file with *.cif, Quicktime Player wouldn't play it.
    mike
The file format is not supported
Hi driddle00...
This information came from the Microsoft WebPage:
"Cannot play back the file. The format is not supported. This behavior occurs because PowerPoint can play back only QuickTime movies (.mov and .qt files) that use compression schemes with corresponding Media Control Interface (MCI)-compatible codecs.
A codec (compressor/decompressor) is an algorithm or scheme that is used to record digital video or audio. For example, when you transmit video over the Internet, the video must be compressed on the sending end and decompressed on the receiving end. A codec can be chosen based upon the user's audio or image quality and image size preferences.
When you read a QuickTime movie, a Video for Windows decompressor decompresses the QuickTime files. If the decompressor does not support the compression method used by the QuickTime movie, the decompressor cannot display the movie on the screen.
To work around this behavior, use one of the following methods. uparrow.gifBack to the top Method 1: Create a hyperlink to the .mov file loadTOCNode(2, 'workaround'); Create a hyperlink to the .mov file, and then let the QuickTime Player for Windows play the file instead. To do this, follow these steps:
  1. Select the object or text that you want to assign the hyperlink to.
  2. On the Insert menu, click Hyperlink.
  3. Under Link to, click Existing File or Web Page.
  4. Select the QuickTime movie that you want to play, and then click OK.
    Note Under Look in, click Current Folder to see a list of files, click Browsed Pages to see a list of recently viewed Web pages, or click Recent Files to see a list of recently used files.
During the slide show, click the linked object or text to play the movie. If a valid player is available, the player starts, and then the player plays the QuickTime movie. uparrow.gifBack to the top Method 2: Convert QuickTime movies to AVI format loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
You can use other QuickTime editing programs instead of QuickTime 4.0 Pro. To do this, see the QuickTime documentation for the relevant steps.
To convert the QuickTime movies to AVI format, follow these steps:
  1. Start QuickTime Pro, and then open the file that you want to convert.
  2. On the File menu, click Export.
  3. Set the Export file type to Movie to AVI.
  4. Click Options, and then click Settings.
  5. In the Compressor group, click the list of compressors, and then select one from the previous list. Cinepak is a popular format. Select the format that you think works best with the movie.
  6. Make sure that you change the extension on the file name to .avi, and then click Save.
uparrow.gifBack to the top Method 3: Recompress the QuickTime movies with compatible codec loadTOCNode(2, 'workaround'); Note In the following steps, you must use QuickTime 4.0 Pro. You cannot follow these steps with the basic version of QuickTime 4.0. The steps are the same for both Windows and Macintosh versions of QuickTime 4.0.
To recompress the QuickTime movies with compatible codec, follow these steps:
  3. Set the Export file type to Movie to QuickTime Movie.
  6. Click Save.
uparrow.gifBack to the top Verify that QuickTime movies are compatibleYou can use Microsoft Media Player to... loadTOCNode(1, 'moreinformation'); Verify that QuickTime movies are compatible loadTOCNode(2, 'moreinformation'); You can use Microsoft Media Player to verify that a QuickTime movie is compatible with PowerPoint.
Note Microsoft Media Player (Mplayer.exe or Mplay32.exe) is a different program than Windows Media Player. Microsoft Media Player is included with various versions of the Windows operating systems, and is an MCI-compliant device. Windows Media Player, however, is a new technology that does not rely on MCI to play various forms of media. Windows Media Player can play a wider range of video and audio formats than Microsoft Media Player can play.
To determine the compatibility of the movie, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type the appropriate command for your operating system:
    • In Microsoft Windows 98 or Microsoft Windows Millennium Edition, type mplayer.exe, and then click OK.
    • In Microsoft Windows NT 4.0, Microsoft Windows 2000, or Microsoft Windows XP, type mplay32.exe, and then click OK.
    Microsoft Media Player starts.
  3. On the File menu, click Open.
  4. Select the QuickTime movie that you want to verify. Click Open.
If the QuickTime movie is compatible, Microsoft Media Player opens the movie. If Microsoft Media Player opens the movie, but PowerPoint does not, there may be a problem with PowerPoint or with the MCI settings. If Microsoft Media Player does not open the movie, and then you receive an error message in Media Player, the movie is not compatible and cannot be played in PowerPoint. You may be able to make the movie compatible by using one of the methods described in the WORKAROUND section of this article."
Sep 06, 2011 | Philips GOGEAR SA6045 MP3 Player
I CAN NOT PLAY MUSIC USING MY MEDIA PLAY
windows media does not support all extensions. Below are the examples. if you have the right format and still you are not able to play then best option is to upgrade or reinstall media player. Windows Media Player 6.0 loadTOCNode(2, 'moreinformation');
  • Windows Media formats
    File name extensions: .asf, .asx, .avi, .wav, .wma, .wax, .wm, .wmv, .wvx
  • RealAudio and RealVideo (version 4.0 or earlier)
    File name extensions: .ra, .ram, .rm, .rmm
  • Moving Pictures Experts Group (MPEG)
    File name extensions: .mpg, .mpeg, .m1v, .mp2, .mpa, .mpe
    Note MPEG 2 requires third-party software or hardware decoders.
  • Musical Instrument Digital Interface (MIDI)
    File name extensions: .mid, .rmi
  • Apple QuickTime (version 2.0 or earlier)
    File name extensions: .mov
  • Macintosh AIFF Resource
    File name extensions: .aif, .aifc, .aiff
  • Intel Video File
    File name extensions: .ivf
  • UNIX
    File name extensions: .au, .snd
Windows Media Player 6.1, 6.2, 6.4, 7, 7.1, Windows Media Player for Windows XP, and Windows Media Player 9 Series loadTOCNode(2, 'moreinformation');
    File name extensions: .asf, .asx, .avi, .wav, .wax, .wma, .wm
  • Audio Visual Interleave
    File name extension: .avi
    File name extensions: m3u, mp2v, .mpg, .mpeg, .m1v, .mp2, .mp3, .m3u, .mpa, .mpe, mpv2
  • DVD Video
    File name extension: .vob
    Note DVD playback requires third-party software or hardware decoders and is supported only in Windows XP.
    File name extensions: .mid, midi, .rmi
  • Apple Macintosh AIFF Resource
  • Sun Microsystems and NeXT
  • Intel Video File
    Note Intel Video File support requires the Intel Video 5.x codec.
  • Windows Media Player Skins
    File name extensions: .wmz, .wms
  • QuickTime Content
    File name extensions: .avi, .mov, .qt
    Note Windows Media Player can play back older forms of the QuickTime format only. For additional information, click the following article number to view the article in the Microsoft Knowledge Base: (http://support.microsoft.com/kb/316992/EN-US/ ) Windows Media Player Multimedia File Formats
  • Algebraic-Code-Excited Linear Prediction
  • UNIX
  • Macromedia Flash
    File name extension: .swf
Dec 10, 2010 | Gateway M350CS PC Notebook
Can't play the videos I've recorded...
The panasonic vidoe are in quicktime - you will need to either download quicktime software to run the vidoe clips or you can convert the file format from quicktime into windows media player format. The codecs you are downloading may convert your files but I am not familiar with GO.
I suggest you download quicktime for now, so you can at least play your vidoes. be sure to check your operating system for the download.
http://www.apple.com/quicktime/download/
At a later date, you may or may not want to edit them in which case you can download a conversion tool or do so online.
Mar 23, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Icecam2 sound
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Feb 25, 2009 | Macally IceCam Personal Web Camera
Hi There, I have got a DVD RW 8cm disc(recorded some video on SONY 105E DVD Camcorder) which i was not able to playback on my sony vaio laptop. Any solution to fix this problem,please
Your problem is most likely a format or codec problem.(you dont have the right one installed)
Download the free VLC media player here
http://www.videolan.org/vlc/
Its a free program that plays almost everything, without the need for downloading new codecs all the time.
If by chance this does not solve the problem, take note of the file extension of the file you are trying to play.
Google "extension + .avi" to find out what plays an avi file
google "extension +.mov" to find out that that is a QUICKTIME file.(which very well maybe as its very popular for movie cam formats)
If you dislike using VLC for some reason then you can buy and install the proper program to play the proper file kind *s* but VLC will play 99 % of files.
Thank you and good luck.*s*
Oct 26, 2008 | Computers & Internet
Video Files not Recognized
Dont know much about the MAC but most time this happens some other program takes over video and picture viewing check to see if this is the case. what ever proram you use for videos etc ensuure its the default one
Hope this helps
Jul 20, 2008 | Macally IceCam Personal Web Camera
Sound doesn't transfer from camera into computer
It most likely IS the .mov file. I recommend buying quicktime pro, $20,  which will allow you to convert the file, or if you get the free version of quicktime, and the video and audio play fine with it, You can use a screen recorder and turn off the "record external Mic" mode, and turn ON "Record Computer Audio" Once you're done converting (or recording) You can go ahead and edit, Hoped this helped- sincerely: animation508 (youtub username)
Jun 18, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Problem with macally icecam
1. You can open only one video application at a time, therefore, you need to quit ALL the application first, then open the one application you want to use. such as YIM or Skype.
2. Please open the iceCam Monitor, go to Monitor tab, check the "Record Video" and select "Record Until MouseClick".
A new Save window will pop up, set up the filename and location and click SAVE button.
Once you click the mouse button, it will save the recorded video as QuickTime Movie clip format file on the selected location.
If you want a picture, you could run the video and pause it and make a screen shot to grab the picture from the video.
Dec 25, 2007 | Macally IceCam Personal Web Camera
QuickTime movie mode
The D-580 Zoom does play back sound in QuickTime® movie mode.
Sep 01, 2005 | Olympia OL-5805 Cordless Phone
Macally IceCam Personal Web Camera Logo
167 people viewed this question
Top Macally Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
David
David
Are you a Macally Computer and Internet Expert? Answer questions, earn points and help others
