Question about Poulan "" Push Mower
Lawn mower engine stops while pushing
It is a Poulan Quantum XTE mulcher/mower with a 4.5hp engine, someone just gave it to us. It starts pretty easy but runs at a low idle. It has the big back wheels. It also says mulcher on it. It is not gummed up with grass. The throttle sticks so I just put WD 40 on it. Like I said it is running at a very low idle and using alot of gas, but when I force the throttle up it sounds great then conks out unless I lower the throttle to a very low idle. The blade is sharp so it cuts easily for 5 to 10 minutes then, even if it is on the pavement it just conks out. It starts again with one pull and then conks out again.
    President:
  • 1,627 Answers
Sounds like the float is set too low or you need to clean the carb.check the fuel filter and tank screen also.
Posted on Jul 29, 2009
Where do i find the owners manual for a mastercraft quantum xte 5hp lawnmower engine
try for a pdf version on the manufacturers site on the net
Jun 07, 2015 | Garden
Where would I find an owners manual for a briggs and stratton quantum xte 4.5 hp push mower engine
you can order one from your local briggs dealer. what information are you looking for?
Sep 06, 2014 | Garden
Hi, Received a used poulan we940rc with broken cable (start, turtle, rabbit). Cannot start engine. Check no sparks on spark plug? Magneto dead? Any manual so I can try to repair if not will scrap. Cao...
You can check for spark by removing the spark plug, reattaching the plug wire and grounding the plug to the head and having someone pull the starter while watching the plug. The start position on the throttle cable actuates the choke on the carb, which is pretty important for a mower with a throttle cable in order to get it to start. Get the model number off the back of the mower and take it to a small engine repair parts shop.
If really helpful, please rate.
Jul 12, 2011 | Poulan "Poulan" Push Mower
B&S Quantum Power 4hp won't start with fresh plug,
Did it run before you changed the plug?Gap is correct, flywheel shear pin may be bad, Water in the Gas?
Jul 02, 2011 | Poulan "" Push Mower
The engine is not started
Hi.
Check the blade... it is bent and causes a vibration. if it is not the blade then the motor shaft is bent and that is terminal...if that happened then the mower is junk...
heatman101
Jul 12, 2010 | Poulan "Poulan" Push Mower
I need an intake for a poulin push mower with a
"Model-Type-Code" numbers on a Quantum Series are usually located on the sheet metal right above the muffler. If not there, remove the plastic cover from the blower housing and check on the blower housing near the spark plug wire.
Hope this helps
Oct 02, 2009 | Poulan "Poulan" Push Mower
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Lawn mower engine shuts off after about 15 secs of starting.
Possible solutions:
-Water or trash (or both) is in the gas tank which means you must empty all gas from the tank and refill with fresh gas. The carb. will need to have all old gas removed too. If this is the case you will want to empty your gas can too because it may be the source of the water/trash.
-Replace the priming bulb.
Jul 29, 2009 | Garden
Locked blade - poulan push mower
Check the oil level in the engine...if the blade is locked up, so is the engine, sorry
Apr 05, 2009 | Poulan "Poulan" Push Mower
Poulan "" Push Mower Logo
527 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
