Question about Frigidaire FGB24S5A Gas Single Oven
MY oven is not working. The burners and broiler do work.This is a gas oven.
    President:
  • 704 Answers
If you can see the oven ignitor glowing bright orange when you turn theoven control on to say 350 degrees. (look down at the back bottom of the oven compartment near the back wall of the oven).
If there is no glow, then you have a faulty ignitor. If you can see the ignitor glowing and the owen doesn't light, then it is the thermocouple that controls the flow of gas from gas supply valve that is bad.
You'll need to replace the defective part(s) to get the oven working properly. You can find the parts on the link included along with some pricing at searspartsdirect.com but you can buy parts anywhere you wish.
You'll have to pick which oven version you have as you need one more letter at the end of your model number (it's usually a small printed letter after the larger model number on the label eg: A, B, or C.) so you can look at the parts list to select the correct parts for your oven.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=gKpqVBTSaohlK3kbhZ+WFQ**.shcapp3105?modelNumber=+FGB24S5A+&pop=flush
Hope this helps you get cooking again! Best Regards!
Posted on Jul 31, 2009
I found that it could also be a weak ignitor. not drawing enough current to tell the gas valve to open. if the ignitor has some white on it its probibly bad.
Posted on Oct 31, 2012
My oven is not working The Broiler works and the stove top works fine but the oven will not heat and when you turn it on no gas comes out I tried turning it on and using a lighter but nothing happens
You gave us good clues in information!-- Thanks!
Most modern gas ovens have a device called a Glow Ignitor to light the burner.
If this ignitor has filed, it will NOT left the gas valve open-- (Good thing, right? :-) )
You say the broiler lights fine-- so let's observe something when the Broiler lights:
Do you see a bright glow near the Broiler burner?
(Usually toward the top rear of the oven--)
Well, you should see a similar bright glowing near the BOTTOM rear of your oven, for the main burner to light off-- If you do NOT see this glowing-- then you need a new ignitor-
You can remove the bottom burner cover, and dig deeper into the repair if you like-
But a new ignitor needs to be exactly like the failed one-- the safety circuit is very fussy about the exact same ignitor-- or it will not allow lighting-- even with a new 'generic' installed.
How deep do you want to go into this repair?-- Maybe it is time to call the service people into do the job?-- You can tell them that you think the ignitor needs replacing-- and approx. what will they charge you for the service call and the ignitor?
I hope this helped.
Mack B
Jan 27, 2011 | GE 30 In Freestanding Gas Range ...
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Jennair gas oven. lower burner won't light, i.e.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Jul 16, 2010 | Jenn-Air JGW8130DD Gas Single Oven
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
heatman101
Mar 30, 2010 | Ovens
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Sf195lehz5 free standing gas oven,
Check both gas valve solonoids for 216 ohms [blue broiler wire to the orange common and red oven wire to orange common] both must be ok.
Check oven temp sensor for 1080 ohms.
If above are ok then the problem is either the spark module or the control board.
Since the gas valve was not opening and there was not ignitor sound I replaced the spark module for about $90. You have a 50-50 chance of being right.
My range is relitively new and I'm haveing an oven light problem which I traced to the control board so I may replaced this board to for about $200.
HS
Oct 05, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Frigidaire FGB24S5A Gas Single Oven Logo
1,200 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
