Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Have verified signal is coming from box. Responds to menu but no picture comes up. Red stand by/stereo light blinks. Aii I have is audio and for the prior 10 years I have never had a problem with the tv.
    Novelist:
  • 112 Answers
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Posted on Jul 29, 2009
How do I fix my Sony TV?
Sir
please one thing remember that red led blinking indicate specie fault please watch red light count and find the correct fault which is written below
Monitoring Items Number of Flashes of red led Main Power Supply Voltage Error 2
DC_ALERT1 3
DC_ALERT2 4
DC_ALERT3 5
Backlight Error 6
Internal Temperature Error 7
Audio Error 8
Digital FE Error 10
Trident Error 11
Balancer Error 13
T-CON Error 14
thanks
Sep 22, 2017 | Sony Televison & Video
Sharp sound problems no sound
Just check if the audio signal cable is getting into the Sharp panel. If you are using HDMI then select the audio in to HDMI. I am unclear if your audio was previously coming in from the stereo or the cable box. If you have removed the stereo then you need to ensure the audio signal to the panel is stored. Not sure if this helps.
Aug 02, 2014 | Sharp LC-70LE632U - 70 Aquos Edge Lit Led,...
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Disc™ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
The picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
the picture comes for 2 secs on the screen and immediately goes to stand by and red LED Sony bravia standby mode blinks 8 times
Nov 19, 2010 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony 32" tv red light flashes then picture blinks on and off continuesly
We end up hitting the side of the tv. Literally hitting the side of the tv box.
May 30, 2008 | Televison & Video
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by...
Takes about 5 minutes for picture to appear... Then every one to two minutes the picture disappears. It comes back on for 1 - 2 minutes then repeats. When set if first turned on, the stereo/stand-by light (red) flashes on/off until just before picture first appears .if your tv is very old than it might be due to crt getting weak crt base loose loose contact in power supply thanks
Sep 09, 2007 | Sony KV-32S12 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
280 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
