Question about HP Officejet Pro L7780 All-In-One InkJet Printer
L7680 Continues to report out of paper
Will not load paper from paper tray, reports out of paper,
sheet feeder wheel will not engage to load paper
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
Does this help?
Posted on Aug 03, 2009
Paper feeder stuck
If the paper feeder stuck, do the following:
  1. Gently pull any jammed paper out from the output tray or sheet feeder.
  2. If paper is stuck inside, open the printer cover and remove the jammed paper, including any torn pieces. Then close the printer cover.
  3. If paper remains near the sheet feeder, press the paper feed roller lever inside the paper feeder to release the jammed paper, then carefully pull it out.
  4. Load the paper correctly.
  5. Press the cp_button_14.gif stop button to resume printing.
  • If the printer continues to jam or misfeed paper, and you are certain that there are no foreign objects lodged down inside the paper feed area, your printer may require service. Please call Epson technical support for further assistance.
  • Jan 29, 2011 | Epson Office Equipment & Supplies
    Paper jam
    Dear sir,
    i am giving u setp to solved your problem,
    Step one: Remove any loose paper.
    Step two: Clear the jam from the back of the All-in-One
    Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
    Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
    How to fax
    Load an original in the automatic document feeder (ADF)
    You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
    placing it in the document feeder tray.
    The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
    sheets of legal-size paper.
    To send a basic fax from the control panel
    1.
    Load your originals. For additional information, see Load originals.
    2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
    dial button to select a speed dial, or press Redial/Pause to redial the last number
    dialed.
    TIP: To add a pause in the fax number you are entering, press Redial/Pause,
    or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
    3. Press START FAX Black.
    If the device detects an original loaded in the automatic document feeder, it
    sends the document to the number you entered.
    TIP: If the recipient reports issues with the quality of the fax you sent, you can
    try changing the resolution or contrast of your fax.
    for further refernce check out the online manual
    http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
    Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
    Paper won't load and printer is reporting an E2 error code. The paper seems to be loading only on one side or edge... Can this be fixed? I have tried resetting the printer and turning it off and on again.
    There is some object who block paper in sheet feeder.Look inside sheet feeder using flashlight and try to find the object.The bad think is in most case the object who block the paper is in under the withe rollers and you need to disassembly the hole printer to find it.
    Nov 16, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Hp printers continue to jam
    Print a self-test report Use the following steps to print a self-test report.
    1. Load plain white paper in the input tray.
    2. Press Setup , and then press 2 . The Print Report menu displays.
    3. Press 1 to select and print a Self-Test Report .
    IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
    Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Error message says"out of paper" when paper tray is fully loaded
    check and make sure that the paper is in near the rollers enough that it senses the paper and picks it up. try lightly pushing the paper down toward the rollers as it is suppose to pull one sheet through the feeder. hopefully, you didnt pull too hard on getting the 'jammed' paper out that it may have caused a misalignment in the feeder. try assisting the paper, that usually fixes it. hope this helps!
    Aug 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
    Epson stylus C43UX. my printer keeps saying paper jam and paper not loaded correctly and just spills out the paper i load. the paper is loaded perfectly but it just wont print! the stupid red light just...
    The printer reports a paper jam because the paper feed system cannot feed paper.
    Look down into the place where the paper goes (the "automatic sheet feeder" or ASF) and you should see a fat wheel with a grey ribbed rubber facing. Place a single sheet of paper in the ASF and do a test print (right click the printer icon and select properties). Watch to see what happens in the ASF. The plastic panel behind the sheet of paper should move forward to push the sheet against the rotating rubber wheel, which should then feed the paper into the print position. This is presumably not happening! Can you what does happen?
    If the expected movements are not happening, you need to remove the printer top cover to see what the problem is and resolve it - perhaps the ASF has come loose or something. This is easy if you know how to do it - otherwise it's likely to cause you to take a large hammer to the task! If you need help on this, please report back with a new post.
    Mar 27, 2009 | Epson Stylus C43UX InkJet Printer
    SCX 4521F multi/f keeps reporting "Document Jam"
    Hello there,
    If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
    Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
    Close the front cover.
    Press the power button to turn the printer back on.
    Resend your document to print.
    Ensure that:
    The paper is a recommended paper for Laser printers.
    You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
    The printer is on a flat, level surface.
    The left paper guide is against the side of the paper.
    You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
    The left paper guide does not cause the paper to bend in the sheet feeder.
    Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
    Envelopes or the appropriate specialty papers are selected in the printer driver.
    You are using a paper or envelope size supported by your printer.
    do not forget to rate this solution....good luck
    thanks for using FixYa
    Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
    Top feeder won't work properly
    hello!
    have you tried cleaning the separator pad inside the automatic document feeder?
    try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
    If the problem persists, clean the rollers and separator pad manually
    May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
    Lexmark e320 thumping on feed
    The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
    1. Confirm that no foreign materials are inside the machine.
    2. Confirm that usable paper is set.
    3. Confirm that the paper is set properly.
    4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
    5. Adjust the paper feeder guide to the sheet size.
    6. Disconnect the printer power cord as well as the printer cable form the printer.
    7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
    Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
    8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
    9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
    10. Try printing with having only one sheet in the feeder and check if it does work.
    Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
    Regards
    Malik Khan
    Jan 31, 2008 | Lexmark E320 Laser Printer
    HP Officejet Pro L7780 All-In-One InkJet Printer Logo
    194 people viewed this question
    Seeker5211
    Seeker5211
