If the fan is moving air at the proper velocity, it is most likely a clog in the heater core or the hose leading into it. Generally, there are 2 hoses about 1 inch in diameter going through the firewall. Those hoses go into a small radiator inside the cars passenger compartment. Go to YouTube and look for 2002 Silhouette heater core removal for specifics. If warm radiator water won't flow freely through the core, that's the problem.
SOURCE: 2002 caravan, heater problems
That was a common complaint a few years back, due to the fact that the heater core is a little too much higher than the engine, which requires that extra push it gets when engine RPM's increase. One thing I did do on my Caravan was remove my hoses to the heater core, and use a small external pump with hoses to circulate C.L.R. through my core for a while, then let it sit with CLR in the core overnight.Next day I circulated it through again, both ways by reversing hoses, and then re-attached hoses, bled air out of system, and notice quite an improvement in heat at idle. Once cleaned out, the heater core allowed coolant flow through it better at idle. If your stumped by explanation, take it to an automotive shop, or a Rad shop, and get a quote on flushing that core out for you. I recommend the CLR, but it might be too time consuming for you , but a flush will probably show some noticeable improvement.
SOURCE: heater not hot
does the heater core get hot, check the coolant hoses going to the core to see if both are hot, if they are U have a air temperature control blend door problem, most likely the actuator for the door has failed.
SOURCE: ford mondeo mk3, intermitent dumping of water from
You may have an air pocket in your system which some times happens. One way to get rid of it is to take the upper hose off on the engine side, fill your system with water until it runs out from your engine block, replace the hose, start your car turn you heater on and set to hi keep the radiator cap loose until the temp start to rise then close tight. Once the air pocket had been remover you can drain some of the water from the radiator using the lower drain plug and add antifreeze.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
Engine Overheats and heater
blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers
side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
This will help.Thanks.
This could also be caused by the mechanical flap that redirects the air through the heater core being stuck in the vent position. You may want to try hitting any large enclosures usually under the glove compartment area with your hand or a small rubber mallet. This will sometimes free up the flap that may have some debris holding it in the vent position, as it has likely been in that position all summer.
